Use Adafruit.io Slider to Trigger Relay
by bpjmalone on Sat Apr 13, 2019 3:30 pm
Hello, I want to use the slider icon to control the temperature at which a small motor turns on. I am working with a Feather Huzzah, a 5VDC SRD relay, and the Arduino IDE. In my Adafrui.io dashboard, I have a temperature and settemp feed. I believe that my project is similar to this one where triggers are discussed, but I want the trigger to cause the relay to close a normally open switch, not just to send a message:
https://forums.adafruit.com/viewtopic.php?f=56&t=150258&p=742049&hilit=set+temperature+adafruit+io#p742049
My code looks like this (adapted from Adafruit's example - thank you very much!):
// Adafruit IO Temperature & Humidity Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-temperature-and-humidity
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016-2017 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
// pin connected to DH22 data line
#define DATA_PIN 2
//Relay Pin Variable
const int relayPin = 15;
// create DHT11 instance
DHT_Unified dht(DATA_PIN, DHT11);
// set up the 'temperature' feed
AdafruitIO_Feed *temperature = io.feed("temperature");
AdafruitIO_Feed *settemp = io.feed("settemp");
// Figure out how to receive 'settemp' value from Adafruit IO into this program!
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  // initialize dht11 (changed from dht22)
  // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.println(io.statusText());
    delay(500);
  // we are connected
  Serial.println();
    // Pin Setup/Register
  pinMode(relayPin, OUTPUT);
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  float celsius = event.temperature;
  float fahrenheit = (celsius * 1.8) + 32;
  Serial.print("celsius: ");
  Serial.print(celsius);
  Serial.println("C");
  Serial.print("fahrenheit: ");
  Serial.print(fahrenheit);
  Serial.println("F");
  // save fahrenheit (or celsius) to Adafruit IO
  temperature->save(fahrenheit);
  // put your main code here, to run repeatedly:
  // if fahrenheit goes above settemp degrees, turn on motor
  if(fahrenheit > 'settemp'){
    powerOnRelay();
  } else if (fahrenheit <= 'settemp') {
    powerOffRelay();
 delay(1000); // Check tempertature every 1 second
void powerOnRelay() {
    digitalWrite(relayPin, HIGH);
    Serial.println("Relay On");
void powerOffRelay() {
    digitalWrite(relayPin, LOW);
    Serial.println("Relay Off");
Any suggestions? Thank you.
My dashboard:
bpjmalone
Re: Use Adafruit.io Slider to Trigger Relay
by brubell on Mon Apr 15, 2019 10:40 am
Take a look at the subscribe example sketch. Set up your sketch to subscribe to the feed which the slider is connected to.
Whenever the feed value changes, the feed's handler function will fire. From within that function, you'll check against a predefined value, and call either powerOnRelay or powerOffRelay depending on the value.
brubell
by bpjmalone on Mon Apr 15, 2019 2:20 pm
Thank you for your reply, I have incorporated the handler function into my code (lines 117-151). I did not make clear in my initial question that I intended for my code to continuously compare temperature values continuously measured by sensors with the 'settemp' value set in Adafruit.io in order to make a "relay on" or "relay off" decision. My goal is for this comparison to happen regularly (after every ~10 seconds, say), not just when a change to the dashboard item 'settemp' happens. I am trying to make a smart thermostat, in a nutshell. Is that kind of continuous comparison between Adafruit.io 'settemp' values and measured temperatures possible? If so, how?
Code with changes (thank you very much!):
#include "config.h"
#include <DHT.h>
#include <DHT_U.h>
#define DATA_PIN 2
// create DHT22 instance
DHT_Unified dht(DATA_PIN, DHT11); //changed from DHT22
int relayPin = 15;
// set up the 'temperature' and 'humidity' feeds
AdafruitIO_Feed *humidity = io.feed("humidity");
  while(! Serial);
  // initialize dht11
  dht.begin();
  io.connect();
  // set up a message handler for the settemp feed.
  // the handleMessage function (defined below)
  // will be called whenever a message is
  // received from adafruit io.
  settemp->onMessage(handleMessage);
    delay(500);
  // Because Adafruit IO doesn't support the MQTT retain flag, we can use the
  // get() function to ask IO to resend the last value for this feed to just
  // this MQTT client after the io client is connected.
settemp->get();
  // we are connected
  Serial.println();
  io.run();
  // save fahrenheit temperature to Adafruit IO
  delay(3000); // Check tempertature every 3 seconds
// this function is called whenever a 'settemp' message
// is received from Adafruit IO. It was attached to
// the settemp feed in the setup() function above.
// Can the logic below be used continuously, not ust if a change occurred to 'settemp' in my Adafruit.io?
void handleMessage(AdafruitIO_Data *data) {
  Serial.print("received <- ");
  Serial.println(data->value());
  io.run();
    if(fahrenheit > settemp){
    powerOnRelay();
    } else if (fahrenheit <= settemp) {
    powerOffRelay();
bpjmalone
by bpjmalone on Mon Apr 15, 2019 4:59 pm
This part of the MQTT API documentation about retrieving "Last Data in Queue" seems promising, but I am too new to programming to really understand how to implement it:
https://io.adafruit.com/api/docs/#operation/lastData
This project uses input from the Adafruit.io dashboard to control a lamp. This bit of code in the sample project imports strings for "ON" and "OFF," but I want to import numbers from the dashboard. Is that possible? Thank you again for your hard work, you guys are amazing!
while (subscription = mqtt.readSubscription(1000)) {
  // we only care about the lamp events
  if (subscription == &lamp) {
    // convert mqtt ascii payload to int
    char *value = (char *)lamp.lastread;
    Serial.print(F("Received: "));
    Serial.println(value);
    // Apply message to lamp
    String message = String(value);
    message.trim();
    if (message == "ON") {digitalWrite(lamp_pin, HIGH);}
    if (message == "OFF") {digitalWrite(lamp_pin, LOW);}
bpjmalone
by brubell on Mon Apr 15, 2019 6:25 pm
Instead of converting characters, like in the example:
You would want to cast the incoming MQTT data as a number so you can compare it against another number. Data from adafruit IO needs to be converted.
Check out the type conversion (example 05) reference included with Adafruit IO Arduino, specifically the handleMessage function:
https://github.com/adafruit/Adafruit_IO ... n.ino#L137
Converting to a double:
https://github.com/adafruit/Adafruit_IO ... n.ino#L154
Converting to an int:
https://github.com/adafruit/Adafruit_IO ... n.ino#L164
Converting to a float:
https://github.com/adafruit/Adafruit_IO ... n.ino#L160
Keep in mind - the type of data you are comparing needs to be the same. If you are comparing a `float celsius` value to an incoming piece data, the incoming data should first be converted to a `float`.
brubell
by bpjmalone on Tue Apr 16, 2019 10:25 am
Excellent, this may be exactly what I need to receive "constant" messages from the dashboard to compare to my temperature values. I'll post results later in the week. Thank you.
bpjmalone
by bpjmalone on Thu Apr 18, 2019 6:44 pm
Okay, so I incorporated what I thought would be the right code to convert data from Adafruit.io into an int to compare to int temperature values measured by the DHT11 (thank you for the sample code!):
#include "config.h"
#include <DHT.h>
#include <DHT_U.h>
#include <ESP8266WiFi.h>
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_Client.h>
#define DATA_PIN 2
int relayPin = 15;
//int maxTemperature = 77.00; // The Max Temperature allowed
//int minTemperature = 75.00; // The Min Temperature allowed
  while(! Serial);
  dht.begin();
  io.connect();
  // wait for an MQTT connection
  // NOTE: when blending the HTTP and MQTT API, always use the mqttStatus
  // method to check on MQTT connection status specifically
  while(io.mqttStatus() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  settemp->get();
  // we are connected
  Serial.println();
  io.run();
  int celsius = event.temperature;
  int fahrenheit = (celsius * 1.8) + 32;
  // print out the received value
  Serial.println("----- received -----");
  // value() returns char*
  Serial.print("value: ");
  // get int value
  Serial.print("toInt: ");
  Serial.println(data->toInt());
  if (temperature > settemp){
    powerOnRelay();
  else if (temperature <= settemp) {
    powerOffRelay();
However, the serial monitor only showed the dashboard "settemp" feed being handled once, and it did not power the load on or off after measured temperatures exceeded the "settemp" value. I guess I have two questions:
1. Is my code only receiving messages from Adafruit.io when the "settemp" value changes? I want messages to be automatically sent to the Arduino code so that the comparison between measured temperatures and "settemp" can occur more or less continuously.
2. Is there a problem with how I am attempting to convert the Adafruit.io data to an int to compare it to measured temperatures in the "handleMessage" function? That does not seem to be happening. Also, when I use the "fahrenheit" variable for measured temperatures in the "handleMessage" function, an error message says that it was not declared in that scope. Any thoughts about how to use the integer value once converted from Adafruit.io?
Once again, thank you for all of your help.
bpjmalone
by brubell on Fri Apr 19, 2019 10:50 am
Yes,
You can manually get the value of settemp in your loop, check out the digital_in example in the adafruit io arduino library.
Try redeclaring celsius and fahrenheit as 'floats', not ints.
brubell
by bpjmalone on Fri Apr 19, 2019 1:53 pm
Thank you for your reply. The example code you pointed me to seems to only publish to Adafruit.io, not receive from it.
https://learn.adafruit.com/adafruit-io-basics-digital-input
Also, the "output" version only receives when something changes at the dashboard.
I am new to programming in general, but I just don't see how to get settemp in the loop() using the example code provided. Thank you for pointing out the Adafruit example sketches, I'll see what else I can find there.
bpjmalone
by brubell on Fri Apr 19, 2019 6:01 pm
This may not be possible within Adafruit IO Arduino - it uses a mix of the MQTT and HTTP API and you can't select which one you're using like you can in Adafruit IO Python/CircuitPython.
brubell
by bpjmalone on Sat Apr 20, 2019 6:11 pm
I understand, and thank you for bringing me this far. Looks like it's time to learn some Python! If I manage to make my project work with Arduino by some miracle, I'll leave it here for posterity.
bpjmalone
by brubell on Mon Apr 22, 2019 9:27 am
bpjmalone wrote:I understand, and thank you for bringing me this far. Looks like it's time to learn some Python! If I manage to make my project work with Arduino by some miracle, I'll leave it here for posterity.
No problem, and good luck!
brubell
by bpjmalone on Wed Apr 24, 2019 9:07 pm
Well what do you know, I got my project to do what I wanted it to do!
Code fixes (C++/Arduino):
(1) Add a set temperature and measured temperature compare function which takes the measured temperature as an input from the main loop().
(2) Declare the set temperature as a global variable
(3) Move the relay on and relay off functions to the top of the code so that the compiler recognizes them throughout the rest of the code.
**Not shown: config.h with wifi SSID, wifi password, Adafruit.io key, and Adafruit.io username. You can probably guess why I didn't publish that information.**
#include "config.h"
#include <DHT.h>
#include <DHT_U.h>
// pin connected to DH11 data line
#define DATA_PIN 2
int relayPin = 15;
//Temperature setting (global)
int setting;
// set up the 'temperature' and feed
  // convert the data to integer
  setting = data->toInt();
  // print out settemp value received from dashboard
  Serial.println(setting);
  if (fahrenheit > setting){
    powerOnRelay();
  else if (fahrenheit <= setting){
    powerOffRelay();
void tempCompare(int& n) { //adapted from: https://www.programiz.com/c-programming/c-pointer-functions
  int temp;
  temp = n;
  if (temp > setting){
    powerOnRelay();
  else {
    powerOffRelay();
  delay(5000);
  while(! Serial);
  dht.begin();
  io.connect();
    Serial.print(".");
    delay(500);
    Serial.print(".");
    delay(500);
  settemp->get();
  // we are connected
  Serial.println();
  io.run();
  // save fahrenheit to Adafruit IO
  tempCompare(fahrenheit);
Equipment:
Huzzah microcontroller, DHT11 temperature sensor, SRD 5V 10A relay, battery, wires, Arduino Uno (to act as second 5V source for the relay board from Velleman), computer (for USB voltage source), small DC motor (removed the water pump from an old Keurig coffee machine), wires, 9V battery to power DC motor, and breadboard.
Thanks a million, @brubell! Looking forward to my next project.
bpjmalone
by brubell on Thu Apr 25, 2019 9:49 am
Hurray! Congrats on getting your project working, post up in a new thread if you hit another snag.
brubell
