[SOLVE]Publishing error
by _edx_ on Mon Apr 22, 2019 2:08 pm
Hi there :-)
I'm testing the wolfmqtt library, till now i've been able to connect, auth and subscribe successfully to io.adafruit.com, but i haven't been able to publish, every time i tried to publish a new value always appears the same message:
error saving data on _edx_/feeds/boton0, data missing required value
[Solution]
After many tries, i've found the right package format:
buf[0]   unsigned char   0xA000F7B8   '1'; 0x31
*buf[1]   unsigned char   0xA000F7B9   DLE; 0x12
*buf[2]   unsigned char   0xA000F7BA   NUL; 0x0
*buf[3]   unsigned char   0xA000F7BB   SO; 0x0E
*buf[4]   unsigned char   0xA000F7BC   '_'; 0x5f
*buf[5]   unsigned char   0xA000F7BD   'e'; 0x65
*buf[6]   unsigned char   0xA000F7BE   'd'; 0x64
*buf[7]   unsigned char   0xA000F7BF   'x'; 0x78
*buf[8]   unsigned char   0xA000F7C0   '_'; 0x5f
*buf[9]   unsigned char   0xA000F7C1   '/'; 0x2f
*buf[10]   unsigned char   0xA000F7C2   'f'; 0x66
*buf[11]   unsigned char   0xA000F7C3   '/'; 0x2f
*buf[12]   unsigned char   0xA000F7C4   'b'; 0x62
*buf[13]   unsigned char   0xA000F7C5   'o'; 0x6f
*buf[14]   unsigned char   0xA000F7C6   't'; 0x74
*buf[15]   unsigned char   0xA000F7C7   'o'; 0x6f
*buf[16]   unsigned char   0xA000F7C8   'n'; 0x6e
*buf[17]   unsigned char   0xA000F7C9   '0'; 0x30
*buf[18]   unsigned char   0xA000F7B8   'O'; 0x4F
*buf[19]   unsigned char   0xA000F7B9 'n'; 0x6E
Hope it helps somebody else whos dealing with this.
Regards :-)
_edx_
Re: [SOLVE]Publishing error
by brubell on Thu Apr 25, 2019 9:59 am
In the request body, pass in a 'value' field as a string.
https://io.adafruit.com/api/docs/#operation/createData
brubell
