Example adafruitio_00_publish error compile
by RAMM on Tue Apr 23, 2019 2:06 pm
I tried to make the example adafruitio_00_publish but i stumbled upon an error while compiling.
so i followed the arduino IO library from this link https://learn.adafruit.com/adafruit-io-basics-esp8266-arduino/arduino-io-library
and i still get the compiling error for my esp8266.
Error message:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, 4M (3M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp: In member function 'virtual bool Adafruit_MQTT_Client::sendPacket(uint8_t*, uint16_t)':
C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: error: no matching function for call to 'min(uint16_t&, int)'
       uint16_t sendlen = min(len, 250);
C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: note: candidates are:
In file included from c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\algorithm:62:0,
                 from C:\Users\Justi\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/Arduino.h:254,
                 from C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.h:25,
                 from C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.h:26,
                 from C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:22:
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note: template<class _Tp, class _Compare> _Tp std::min(std::initializer_list<_Tp>, _Compare)
     min(initializer_list<_Tp> __l, _Compare __comp)
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note:   template argument deduction/substitution failed:
C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: note:   mismatched types 'std::initializer_list<_Tp>' and 'short unsigned int'
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note: template<class _Tp> _Tp std::min(std::initializer_list<_Tp>)
     min(initializer_list<_Tp> __l)
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note:   template argument deduction/substitution failed:
In file included from c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\algorithm:61:0,
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note: template<class _Tp, class _Compare> const _Tp& std::min(const _Tp&, const _Tp&, _Compare)
     min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note:   template argument deduction/substitution failed:
C:\Users\Justi\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: note:   deduced conflicting types for parameter 'const _Tp' ('short unsigned int' and 'int')
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note: template<class _Tp> const _Tp& std::min(const _Tp&, const _Tp&)
     min(const _Tp& __a, const _Tp& __b)
c:\users\justi\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note:   template argument deduction/substitution failed:
exit status 1
Error compiling for board Adafruit Feather HUZZAH ESP8266.
Why does it not compile?
Reason: Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
RAMM
Re: Example adafruitio_00_publish error compile
by adafruit_support_carter on Tue Apr 23, 2019 4:53 pm
Check and make sure you have the latest versions of all the libraries. And try with version 2.4.2 of the ESP8266 BSP.
by tweil on Tue Apr 30, 2019 4:53 pm
This exact same error occurs with ESP32. I had to downgrade the ESP32 in Board Manager to version 1.0.1.
tweil
