Use 2 urls with PyPortal
by kajmaya on Wed May 01, 2019 12:26 pm
Is it possible to use 2 or more url's with PyPortal? If so how?
My situation is that I get the lon/lat. (I'm do it with the IP here: http://api.ipstack.com) Then I use the returned lon/lat to get data from another URL. Can I do the same using PyPortal?
kajmaya
Re: Use 2 urls with PyPortal
by franklin97355 on Wed May 01, 2019 12:54 pm
What is the code you are using now to get the data? You should be able to drop a connection and make a new one.
franklin97355
by kajmaya on Wed May 01, 2019 1:15 pm
Here is the snippet:
DATA_SOURCE = "http://api.ipstack.com/Local_IP_Here? \
        access_key=Key_Here"
pyportal = PyPortal(
    url=DATA_SOURCE,
    json_path=DATA_LOCATION,
    status_neopixel=board.NEOPIXEL,
    default_bg=0x000000,
and further down I'm using: pyportal.fetch(). Everything works. I just need to use a second URL.
Im intrigued, how do I drop the connection?
Thanks for your help
kajmaya
by brubell on Thu May 09, 2019 10:05 am
You might want to take a look at the CircuitPython_PyPortal library's url parameter:
https://github.com/adafruit/Adafruit_Ci ... al.py#L144
After the initial pyportal.fetch, you can change the URL passed in by changing the url (pyportal._url, via https://github.com/adafruit/Adafruit_Ci ... al.py#L167) and then calling fetch() again.
brubell
