Deleting image datapoint does not actually delete image data
by servetcos on Thu May 02, 2019 9:49 am
Trying to delete a datapoint (image) manually does not work. The pop-up appears and I press OK. But nothing happens after that.
servetcos
Re: Deleting image datapoint does not actually delete image
by abachman on Thu May 02, 2019 10:11 am
Ah! If feed history is off, we store the data in a different spot that's overwritten whenever new data arrives. You didn't mention it, but I suspect since you're sending image (bigger) data, you've turned history off.
This is a bug that'll take a minute to fix, but in the meantime you can just add a blank data point and the old data will be cleared from the system.
- adam b.
abachman
