Calculate additional data from Adafruit IO feeds
by simos_iot on Fri May 03, 2019 1:21 am
I'm trying to minimise the amount of data being sent via a cellular connection due to the way the data is charged.
At the moment we are sending, among other things, temperature, humidity and dew-point. Dew-point is actually calculated from temperature and humidity.
Is there a way in Adafruit IO to read the temperature and humidity values, calculate the dew-point and then add that calculated value to another feed?
simos_iot
Re: Calculate additional data from Adafruit IO feeds
by brubell on Thu May 09, 2019 9:58 am
At this time, Adafruit IO can not perform calculations on data received; the hardware client is expected to take care of that. It's a good idea - and something we're considering adding into the service.
brubell
by simos_iot on Thu May 09, 2019 6:24 pm
Thanks for the update...hope to see a feature like this in the future as it would simplify some operations.
simos_iot
