cannot write data into a shared feed
by troylanier on Tue May 07, 2019 1:13 pm
Problem Statement:
Using the mqtt_shared_feeds.py example from https://adafruit-io-python-client.readthedocs.io/en/latest/feed-sharing.html , I cannot write into another users shared feed on which I have read/write privileges.
Details:
I want user_b to write data into user_a shared feed called 'voltage'. To do this user_a created a feed on user_a account called 'voltage' and invited user_b to join that feed. user_a gave user_b read and write privileges. user_b was able to see user_a 'voltage' feed in HOME:SHARING section of the adafruit.io ui on user_b account.
We then followed this tutorial: https://adafruit-io-python-client.readt ... aring.html for `mqtt_shared_feeds.py`
We put user_b_username into ADAFRUIT_IO_USERNAME = 'YOUR_AIO_USERNAME'
We put user_b private key into ADAFRUIT_IO_KEY = 'YOUR_AIO_KEY'
We put in 'voltage' as the ‘SHARED_AIO_FEED_NAME’
We put in user_b_username as the ‘SHARED_AIO_FEED_USERNAME’
We ran mqtt_shared_feeds.py Our expectation was that data would be written into user_a ’s shared feed called “voltage”. Instead, user_b now has a new group called “user_a_username” and a new feed that user_b owns that sits within that group called voltage. user_b can see data on this feed when logged in as user_b. The original shared feed on use_a account does not show any data.
troylanier
Re: cannot write data into a shared feed
by adafruit_support_carter on Tue May 07, 2019 9:00 pm
Try changing that to user_a.
by troylanier on Tue May 07, 2019 11:10 pm
Thanks. I mistyped. We did indeed put in user_a_username as the ‘SHARED_AIO_FEED_USERNAME’
troylanier
by adafruit_support_carter on Wed May 08, 2019 1:27 am
As far as I can see, you're setting up the share as described here:
https://learn.adafruit.com/adafruit-io- ... ing-a-feed
and modifying the example correctly.
I'd suggest opening an issue in the code repo in case this is some kind of bug:
https://github.com/adafruit/Adafruit_IO_Python/issues
Let me know if you've never done that. I can open one for you.
