Error 603 when using Sim7000 and AT Commands
by krish2487 on Thu May 09, 2019 8:24 am
I apologize in advance if this seems out of place or relevance. I am just trying to get started with adafruit.io for some datalogging.
Let me start off by saying I am just getting started out with adafruit.io and do not have much (if at all) knowledge or experience about the HTTP and REST and APIs and such.
I am fairly comfortable with electronics and microcontrollers. I am trying to use a STM32 processor with libopencm3 and SIM7000 to post some environmental data to adafruit.io.
I understand that it can be done by making a HTTP Post request. I am just trying to manually send AT commands to the SIM7000 using a USB UART converter to check my understanding is right and the data is successfully posted.
The feed is setup and I am able to manually post the data using curl
curl -F 'value=33' -H "X-AIO-Key: *********************" https://io.adafruit.com/api/v2/krish2487/feeds/temp/data
This is what I have tried to do manually by sending AT commands to the module. I am trying to post the same data using HTTP POST request.
AT+SAPBR=3,1,"Contype","GPRS"
OK
AT+SAPBR=3,1,"APN","TM"
OK
AT+SAPBR=1,1
OK
AT+SAPBR=2,1
+SAPBR: 1,1,"10.162.11.38"
OK
AT+HTTPINIT
OK
AT+HTTPPARA="CID",1
OK
AT+HTTPPARA="URL","https://io.adafruit.com/api/v2/krish2487/feeds/temp/data"
OK
AT+HTTPPARA="USERDATA","X-AIO-Key:*******************************"
OK
AT+HTTPPARA="CONTENT","Content-Length: 9"
OK
AT+HTTPPARA="CONTENT","Content-Type: application/json"
OK
AT+HTTPDATA=9,30000
DOWNLOAD
OK
AT+HTTPACTION=1
OK
+HTTPACTION: 1,603,0
I have entered "value=123" after the "DOWNLOAD" message from the sim7000. I keep getting the Error 603 which I understand is a DNS error. I read that it might be related to the APN. I have replicated the same steps with a hologram sim and a thingsmobile sim but the same issues persisted.
I suspect it is something I am doing wrong while constructing the body of the POST request. I will be extremely grateful if someone can point out what I am doing wrong.
I am aware that the Arduino FONA library can do the job, but I would like to learn how to do it myself since the final application is an STM32 processor with gnu arm toolchain and libopencm3.
Thanks in advance.
krish2487
Re: Error 603 when using Sim7000 and AT Commands
by brubell on Thu May 09, 2019 9:05 am
Are you able to GET data from a page, like Google.com, with your module?
brubell
by krish2487 on Thu May 09, 2019 9:26 am
Yes I am able to get a response back from google.com
This is what is the output from the module when I execute a GET request for www.google.com
OK
OK
AT+SAPBR=1,1
OK
AT+SAPBR=2,1
+SAPBR: 1,1,"10.162.180.140"
OK
AT+HTTPINIT
OK
AT+HTTPPARA="URL","www.google.com"
OK
AT+HTTPPARA="CID",1
OK
AT+HTTPACTION=0
OK
+HTTPACTION: 0,200,11861
However when I try to execute the same for https://io.adafruit.com, I get the same error 603
This is the output when I try GET for io.adafruit.com
AT+HTTPINIT
OK
AT+HTTPPARA="URL","https://io.adafruit.com"
OK
AT+HTTPPARA="CID",1
OK
AT+HTTPACTION=0
OK
+HTTPACTION: 0,603,0
krish2487
by krish2487 on Fri May 10, 2019 4:59 am
Ok.. after much experimenting with the different methods I found that I could post to the adafruit io using TCP methods.
This is what the logs looks like.
AT+CGATT=1
OK
AT+CSTT="TM"
OK
AT+CGDCONT=1,"IP","TM"
OK
AT+CGACT=1,1
OK
AT+CIICR
OK
AT+CIFSR
10.162.30.221
AT+CIPSTART="TCP","io.adafruit.com",80
OK
CONNECT OK
AT+CIPSEND
> POST /api/v2/krish2487/feeds/temp/data HTTP/1.1
Host: io.adafruit.com
Accept: */*
X-AIO-Key: **************************
Content-Length: 8
Content-Type: application/x-www-form-urlencoded
value=66
SEND OK
HTTP/1.1 200 OK
Server: nginx
Date: Fri, 10 May 2019 08:50:30 GMT
Content-Type: application/json; charset=utf-8
Transfer-Encoding: chunked
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none
Referrer-Policy: strict-origin-when-cross-origin
X-AIO-Worker: io-rails-2
Access-Control-Allow-Origin: *
Access-Control-Allow-Credentials: false
Access-Control-Request-Method: *
Access-Control-Allow-Methods: POST, PUT, DELETE, GET, OPTIONS, PATCH
Access-Control-Allow-Headers: DNT, Origin, X-Requested-With, X-AIO-Key, Content-Type, Accept, Authorization
Access-Control-Expose-Headers: X-Pagination-Limit, X-Pagination-Start, X-Pagination-End, X-Pagination-Count, X-Pagination-Total
Access-Control-Max-Age: 1728000
ETag: W/"4c06688b5073aaa353a1a00c2b832473"
Cache-Control: max-age=0, private, must-revalidate
X-Request-Id: 29a2b4e2-df8d-4b57-b332-47f2d0f8bcc7
X-Runtime: 0.052030
X-AIO-Proxy: 2
e8
{"id":"0E594NVNWJ9J0SJR20G1FGHDXT","value":"66","feed_id":1004087,"feed_key":"temp","created_at":"2019-05-10T08:50:30Z","location":null,"lat":null,"lon":null,"ele":null,"created_epoch":1557478230,"expiration":"2019-06-09T08:50:30Z"}
The Port to be specified in the AT+CIPSTART is really confusing. The documentation mentions that ports 1883 and 8883 are used for MQTT.
Only port 80 works and 443/8443/1883/8883 do NOT work for the above mentioned method. When I tried the above steps with ports other than 80, it simply returns a SEND OK message and nothing else.
However, this is only one part of the problem. The fact that I am able to post using TCP means
1. I should also be able to post using the earlier HTTP Post method
2. There is something wrong with how my HTTP post method is being constructed.
I will be extremely grateful is someone more knowledgeable than me can help me learn. :-)
Thanks in advance.!!
krish2487
by brubell on Fri May 10, 2019 9:50 am
Glad you got it POST'ing. You may find some utility digging through Adafruit IO Arduino's FONA sub-class, it uses the same MQTT port as the documentation specifies. (https://github.com/adafruit/Adafruit_IO ... FONA.h#L36)
brubell
by krish2487 on Fri May 10, 2019 9:59 am
@brubell
Thank you. On a totally unrelated note, I just need a clarification.
If I have to post to multiple feeds, there is no straightforward way to do it in one POST request right.
I need to construct different requests for different feeds.
I know there is MQTT but as I said, this HTTP stuff is blackmagic to me. :-P
Is there is a beginner friendly (read web noobs friendly) write up on adafruit io and at commands for mqtt?
Say, I have a temperature, humidity and pressure sensor. I will need to construct three payloads to post them. Is there a way to post them in one message??
Thank you :-)
krish2487
