(Circuit/Micro)Python and Adafruit Io
by dsblock19 on Wed May 15, 2019 1:19 pm
I have a Raspberry Pi getting sensor data and sending it to Adafruit IO via python.
I needed the Pi so I built a version of the circuit for a feather footprint, but now I can't find any reliable way to use micropython or circuitpython to send the data to Adafruit IO.
My experience so far:
Particle Argon running Circuitpython 4.x - ESP AT control, will, not, work. It picks up my home AP (sometimes) and then just endlessly tries to connect and fails.
(followed this guide: https://learn.adafruit.com/adding-a-wifi-co-processor-to-circuitpython-esp8266-esp32/overview )
Feather HUZZAH ESP8266 running Micropython 1.10 - Connects to wifi, but can't connect to MQTT server (OSError [Errno 103] ECONNABORTED)
(used: https://github.com/miketeachman/micropython-adafruit-mqtt-esp8266)
Feather HUZZAH ESP8266 running Circuitpython 3.x - Module throws an exception (forget which one, but think a variable is not defined)
(used: https://github.com/miketeachman/micropython-adafruit-mqtt-esp8266 again)
I have the code for Arduino, but I just REALLY prefer python. Are there any recommendations for getting the data to Adafruit IO with a microcontroller that runs some form of python?
dsblock19
Re: (Circuit/Micro)Python and Adafruit Io
by brubell on Mon May 20, 2019 10:08 am
The Feather ESP8266 is not supported by the Adafruit CircuitPython Adafruit IO Library, or CircuitPython past 3.x.
Your best bet would be picking up a board with AirLift built in (like the PyPortal or Metro M4 WiFi) or an external AirLift module and follow this guide to use Adafruit IO CircuitPython: https://learn.adafruit.com/adafruit-io- ... cuitpython
brubell
by dsblock19 on Wed May 22, 2019 3:42 pm
Great! That's actually what I ended up doing (Feather M4 Express with Airlift breakout).
It works great, except one thing that is less than ideal: the featherwing adalogger I am using and the tutorial online for airlift both use D10. Is there a way I can (preferably) reassign the SD pin, or (alternatively) switch the airlift's CS pin to something other than D10?
brentru response:
Reassigning the SD Pin may be more difficult since it's a featherwing and has "fixed" pins (it'd require cutting the trace). Since you're using a breakout for the AirLift, you'd be better off swapping the AirLift's CS pin. You can use any DigitalIO on the Feather.
Reason: brentru double posted :o
dsblock19
by dsblock19 on Thu May 23, 2019 10:50 am
Thanks so much! Working perfectly and been chugging along for a day now.
dsblock19
by brubell on Thu May 23, 2019 10:52 am
dsblock19 wrote:Thanks so much! Working perfectly and been chugging along for a day now.
Glad to hear it - let us know if you hit any roadbumps along the way and we'll fix 'em.
brubell
