ESP8266 ESP-12E CP2102 Module NodeMcu
by Justinnnnnnnnnnnnnnnnnnn on Mon May 27, 2019 9:02 am
Good morning, I have problems with the connection, I am using an adafruit code to connect to the Adafruit IO, but there is no way.
I really do not know what is happening;
- If the fault is in the Wi-Fi connection (I have tried it in two different Wi-Fi networks).
- Or if you are in connection with my Adafruit IO account.
- Or if the problem is in the microcontroller, I have also tested it with two different microcontrollers.
Add that I use the IDE Arduino 1.8.5 and I have the Adafruit IO library Arduino by Adafruit version 2.0.6; Adafruit MQTT Library version 1.0.3 and the Adafruit PN532
Someone could help me??
I attach the script.
Thank you
sketch_may27a.ino
(628 Bytes) Downloaded 66 times
Re: ESP8266 ESP-12E CP2102 Module NodeMcu
by Justinnnnnnnnnnnnnnnnnnn on Mon May 27, 2019 9:13 am
I attached a couple of screenshots if they help.
Reason: Brent - removed PDF file in attachments, please upload an image instead.
by brubell on Tue May 28, 2019 10:24 am
hi, can you paste your code with [code][/code] tags and paste a PNG/JPEG image instead of a PDF for security reasons? Alternatively, paste the error message from the serial console as plaintext in your response surrounded by [quote][/quote] tags.
brubell
by Justinnnnnnnnnnnnnnnnnnn on Tue May 28, 2019 6:38 pm
Hello friend, I appreciate you answering.
It does not give me any error in the serial console, and it turns out that I have been able to connect to the Wi-Fi network of my institute, and see the data through the adafruit dashboard, but not in my house I have no way of achieving it.
I thought it was a hardware issue, but I've seen no.
Now I am thinking that it could be because of my Wi-Fi network, because of the configuration issue or something similar that does not let you establish the connection with the microcontroller.
I can not connect ...
#include <Arduino.h>
#include "adafruit.h"//permite al programa de acceder que estan en la pestaña Adafruit.h, ahora podemos utilizar las funciones de otra pestaña
#define SENSOR D8
    pinMode(SENSOR, INPUT);
    pinMode(LED_BUILTIN, OUTPUT);//led builtin es el led de la placa
    //hay que llamar a la funcion despues de serial
    connectToAdafruitIO();
    Serial.println("Connexion activa");
    int movimiento = digitalRead(SENSOR);
    if (movimiento == LOW) Serial.println("Detectando");
    else Serial.println("No detectando");
    sendToAdafruitIO(movimiento);
    delay(2500);
// ESP826 board definition needs to be version 2.4.2 if using Arduino IDE
// or version @1.8.0 if using PlatformIO IDE
// Needs libraries: Adafruit IO, Adafruit MQTT, ArduinoHTTPClient
#include <AdafruitIO_WiFi.h>
#include <AdafruitIO.h>
#define WIFI_SSID "MOVISTAR_26E2"  //nombre de la red #define WIFI_SSID "b&b_gtw"
#define WIFI_PASS  "*******" //#define WIFI_PASS " bits..bits.."
#define AIO_USER "Justinnnnnnnnnnnnnnnnnnn"//usuario de adafruit
#define AIO_KEY "*********" //contraseña de adafruit en  "View AIO Key"#define AIO_KEY "dd77d8e28d1e438997e4cd7eb3be5886"
AdafruitIO_WiFi io(AIO_USER, AIO_KEY, WIFI_SSID, WIFI_PASS); //creamos objetos con la funciony le pasamos los parametros
AdafruitIO_Feed *feed = io.feed("movimiento");                 //le tememos que poner el mismo nombre que le hemos puesto en adafruit, es un feed, una cola de mensajes, siempre la pondremos el minusculas!!
AdafruitIO_Feed *pulsador = io.feed("pulsador"); //nombre del feed en adafruid
//creamos funcion para el pulsador
 void funcionPulsador(AdafruitIO_Data* paqueteDatosDeAdafruit)
 {//esta funcion la llama adafruit
  //para encender el led de la placa
  digitalWrite(LED_BUILTIN,paqueteDatosDeAdafruit-> toPinLevel());    //Te dice donde esta el led en la placa, d1,d2 o lo que sea
  Serial.println(paqueteDatosDeAdafruit ->value());
void connectToAdafruitIO() {//funcion que se conecta a adafruit, cuando se conecte sale de la funcion
  io.connect();
  while(io.status() < AIO_CONNECTED) {
    Serial.println("Connecting to Adafruit IO...");
    delay(500);
  pulsador->onMessage(funcionPulsador); //pulsador es el Feed , recibe como parametro un nombre de otra funcion
//funcion que envia datos, la llamamos en cada ....
void sendToAdafruitIO(int value) {
  io.run();//funcion run, de mantenimiento de la conexion
  feed->save(value);
by brubell on Wed May 29, 2019 9:57 am
Could you try setting your serial monitor to 9600 baud and adding a Serial.println("Connecting to IO..."); line before your call to connectToAdafruit();?
brubell
by Justinnnnnnnnnnnnnnnnnnn on Wed May 29, 2019 11:36 am
I have done what you have told me and I do not get anything more than the message that came to me before, the happy one:
  "Connecting to Adafruit IO ...
Connecting to Adafruit IO ... "
It's infinite.
I can not get out of the loop either ... I do not know what to do.
Thank you
by Justinnnnnnnnnnnnnnnnnnn on Thu May 30, 2019 8:35 am
Hi, I've tried the example of the Arduino id "wifi access point" and it detects my wifi network, but I still can not connect ...
by brubell on Thu May 30, 2019 9:53 am
Justinnnnnnnnnnnnnnnnnnn wrote:Hi, I've tried the example of the Arduino id "wifi access point" and it detects my wifi network, but I still can not connect ...
Are your Adafruit IO key and username correct in the sketch?
brubell
by Justinnnnnnnnnnnnnnnnnnn on Thu May 30, 2019 11:49 am
If the password is correct...
I don't understand anything...
