ESP32 based board won't load Adafruit IO code & errors inclu
by Sam43054 on Tue May 28, 2019 4:35 pm
edit: troubleshooting it also does not want to compile for The Feather ESP32 *not sure if that helps with someone being able to answer
Can anyone help with reviewing the code and error messages trying to upload a modified example of "adafruit_07_digital out"
Platform Mac OSX 10.12.6
Arduino 1.8.9
The latest Adafruit IO, MQTT Libraries
Can not get the below code to load on the "New M5 Stack" from the Adafruit Store --- a ESP32 based board
https://www.adafruit.com/product/4178
background
I've gotten the example to work on Adafruit -- ESP32 ESP8266 and WINC but I can't get it to work on a M5
code--
// Adafruit IO Digital Output Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-digital-output
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
#include <M5Stack.h>
/************************ Example Starts Here *******************************/
// digital pin 5
#define LED_PIN 5
// set up the 'digital' feed
AdafruitIO_Feed *digital = io.feed("digital");
  M5.begin();
  M5.Lcd.fillScreen(BLACK);
  pinMode(LED_PIN, OUTPUT);
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // set up a message handler for the 'digital' feed.
  // the handleMessage function (defined below)
  // will be called whenever a message is
  // received from adafruit io.
  digital->onMessage(handleMessage);
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  digital->get();
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
// this function is called whenever an 'digital' feed message
// is received from Adafruit IO. it was attached to
// the 'digital' feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
  int c = data->toInt();
  M5.Lcd.setCursor(10, 10);
  M5.Lcd.setTextColor(WHITE);
  M5.Lcd.setTextSize(1);
  M5.Lcd.print(c);
Sam43054
Re: ESP32 based board won't load Adafruit IO code & errors i
by Sam43054 on Tue May 28, 2019 4:41 pm
Could not include all of the error message -- due to max limitations
Arduino: 1.8.9 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
/private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/hardware -hardware /Users/D11/Library/Arduino15/packages -tools /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/D11/Library/Arduino15/packages -built-in-libraries /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/libraries -libraries /Users/D11/Documents/Arduino/libraries -fqbn=esp32:esp32:m5stack-core-esp32:FlashMode=qio,FlashFreq=80,PartitionScheme=default,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10809 -build-path /var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/arduino_build_30903 -warnings=none -build-cache /var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/arduino_cache_881472 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/D11/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=/Users/D11/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool_py.path=/Users/D11/Library/Arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=/Users/D11/Library/Arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.mkspiffs.path=/Users/D11/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/D11/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -verbose /var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/arduino_modified_sketch_570191/adafruitio_07_digital_out.ino
/private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/hardware -hardware /Users/D11/Library/Arduino15/packages -tools /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/tools-builder -tools /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/D11/Library/Arduino15/packages -built-in-libraries /private/var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/AppTranslocation/7D050945-39CD-44FC-B90C-A46C8C6801F5/d/Arduino.app/Contents/Java/libraries -libraries /Users/D11/Documents/Arduino/libraries -fqbn=esp32:esp32:m5stack-core-esp32:FlashMode=qio,FlashFreq=80,PartitionScheme=default,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10809 -build-path /var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/arduino_build_30903 -warnings=none -build-cache /var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/arduino_cache_881472 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/D11/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=/Users/D11/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool_py.path=/Users/D11/Library/Arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=/Users/D11/Library/Arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.mkspiffs.path=/Users/D11/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/D11/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -verbose /var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/arduino_modified_sketch_570191/adafruitio_07_digital_out.ino
Using board 'm5stack-core-esp32' from platform in folder: /Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2
Using core 'esp32' from platform in folder: /Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2
Build options changed, rebuilding all
Detecting libraries used...
/Users/D11/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/config -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/app_trace -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/app_update -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/asio -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/bootloader_support -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/bt -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/coap -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/console -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/driver -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp-tls -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp32 -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp_adc_cal -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp_event -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp_http_client -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp_http_server -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp_https_ota -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp_ringbuf -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/ethernet -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/expat -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/fatfs -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/freemodbus -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/freertos -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/heap -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/idf_test -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/jsmn -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/json -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/libsodium -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/log -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/lwip -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/mbedtls -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/mdns -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/micro-ecc -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/mqtt -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/newlib -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/nghttp -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/nvs_flash -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/openssl -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/protobuf-c -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/protocomm -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/pthread -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/sdmmc -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/smartconfig_ack -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/soc -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/spi_flash -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/spiffs -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/tcp_transport -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/tcpip_adapter -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/ulp -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/vfs -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/wear_levelling -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/wifi_provisioning -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/wpa_supplicant -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/xtensa-debug-module -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp32-camera -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/esp-face -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/tools/sdk/include/fb_gfx -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_M5Stack_Core_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"M5Stack_Core_ESP32\"" "-DARDUINO_VARIANT=\"m5stack_core_esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/cores/esp32 -I/Users/D11/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/variants/m5stack_core_esp32 /var/folders/2h/k9h9k70j1c7_26l9dx7v29280000gn/T/arduino_build_30903/sketch/adafruitio_07_digital_out.ino.cpp -o /dev/null
Sam43054
by Sam43054 on Wed May 29, 2019 7:31 am
I’ve also tried on another Mac.. same MacOSX .. Arduino 1.8.7
It compiles the basic “blink” sketch just fine but I get the same exit status 1 for anything in the Adafruit library — for ESP32 or ESP8266
I’ve tried the most recent Adafruit IO and have gone back into the previous ones. Same
Error
My thoughts are since it can do the blink sketch there is something it doesn’t like with the Adafruit library? Or a dependent library? MQTT?
>> All was fine before I updated boards for ESP32 ... before this error I could use any example IO sketch on either a ESP32 or ESP8266 and they worked magically
Sam43054
by brubell on Wed May 29, 2019 9:36 am
Sam43054 wrote:I’ve also tried on another Mac.. same MacOSX .. Arduino 1.8.7
Error
Could you post the compilation output with an ESP32 or ESP8266?
We did change the Adafruit IO Arduino library recently with a breaking change for the ESP8266.
Please make sure you are using the following configuration:
* ESP8266 Board Support Package 2.5.1
* Adafruit IO Arduino Library v3.2
* Adafruit MQTT Library v1.0 (or above)
brubell
by Sam43054 on Wed May 29, 2019 9:49 pm
Did the above! Thanks for the tip. It runs okay now on the ESP8266.. But I need help with ESP32 still (trying to upload to a M5Stack Core)
I included a text file of the compilation output.... please let me know if the file is not what you are looking for... I tried to paste it in here but this forum has a max character count and it exceed it :(
output.txt
(997.55 KiB) Downloaded 57 times
Sam43054
by Sam43054 on Wed May 29, 2019 10:20 pm
Got it!!!
I just played around with backdating libraries. And got it to work on Arduino 1.8.9
You mark as solved. Big help with what Adafruit IO and MQTT to start out with. it felt like over 100 possible combinations between all of the libraries
Sam43054
by brubell on Thu May 30, 2019 9:55 am
It looks like the ESP32 Core has differing function signatures in some methods relied on by ArduinoHTTPClient. For now, downgrade the ESP32's firmware version to 1.0.1.
https://github.com/espressif/arduino-esp32/issues/2755
brubell
