[SOLVED]Need some TLS details
by _edx_ on Fri Jun 07, 2019 7:33 pm
Hi there,
I'm able to establish the comunication without TLS, but now is time to add the secure layer to the conection, so a little help would be appreciated.
Does the TLS of io.adafruit.com uses Public key or Stream ciphers or Hash?
If it's a Public key what algorithm is utilize (RSA, or PSK, etc)?
If it's a Stream does it use (AES, or DES, etc)?
If it's a Hash does it use (sha512, or sha256, or MD5, etc)?
Where can i find the keys or how can i create'em?
Does the IO_KEY is the cert?
_edx_
Re: Need some TLS details
by abachman on Mon Jun 10, 2019 2:30 pm
Hi _edx_,
We offer TLS based connections for HTTPS on port 443 and MQTTS on port 8883. We don't have additional encryption beyond that. You'll need to use https:// or mqtts:// for your connection to be secured.
Using openssl tells me this about our cert:
$ openssl s_client -showcerts -servername io.adafruit.com -connect io.adafruit.com:443 </dev/null
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : ECDHE-RSA-AES256-GCM-SHA384
- adam b.
abachman
by _edx_ on Mon Jun 10, 2019 5:12 pm
Thanks so much abachman, this information will help me to just compile the necessary ciphers.
Regards :-)
abachman wrote:Hi _edx_,
SSL-Session:
    Protocol  : TLSv1.2
- adam b.
_edx_
