AdafruitIO_Feed does not name a type
by mjo2125 on Sat Jun 22, 2019 9:02 am
using the Feather HUZZAH ESP8266 WiFi board with Arduino IDE command and I'm getting the "does name a type" error message during the compiling
I loaded Feather HUZZAH ESP8266 board from board manager
I'm using:
Arduino IDE = 1.8.8
I loaded the following libraries:
Adafruit_IO_Arduino lib = 3.1.0
Adafruit_MQTT lib = 1.0.1
ArduinoHTTPclient lib = 0.4.0
Is this a board problem or a sketch problem?
thanks
mjo2125
Re: AdafruitIO_Feed does not name a type
by adafruit_support_carter on Mon Jun 24, 2019 1:39 pm
What sketch are you running? Is it one of the examples?
by brubell on Tue Jun 25, 2019 9:59 am
Which Board Support Package are you running on the Feather Huzzah? (From the Arduino IDE, Tools->Board->Board Manager-> Search for "ESP8266")
brubell
