error: 'handleMessage' was not declared in this scope
by Loddepus on Wed Jun 26, 2019 12:25 pm
Im new in Adafruit IO and have just got a digital input "command"-feed-tutorial from Instructables to work with NodeMCU and send message to my android.
Now I have made a new analog feed in Adafruit IO called "HjemmeTemperatur".
I copied a code from this tutorial :
https://learn.adafruit.com/adafruit-io- ... duino-code.
I changed the feed name references ("command") in the original code as shown below, but i get this error:
"Wifi_Tempsensor_ERROR:47:31: error: 'handleMessage' was not declared in this scope
HjemmeTemperatur->onMessage(handleMessage);
exit status 1
Tutorial does not show where to declare this. Is it wrong to substitute the feed name !? Please help me...
/************************ Adafruit IO Configuration *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME    ""
#define IO_KEY         ""
/******************************* WIFI Configuration **************************************/
#define WIFI_SSID       ""
#define WIFI_PASS       ""
#include "AdafruitIO_WiFi.h"
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
/************************ Main Program Starts Here *******************************/
#include <ESP8266WiFi.h>
#include <AdafruitIO.h>
#include <Adafruit_MQTT.h>
#include <ArduinoHttpClient.h>
// analog pin 0
#define TEMP_PIN A0
// button state
int current = 0;
int last = -1;
// set up the 'HjemmeTemperatur' feed
// adapted from https://learn.adafruit.com/adafruit-io-basics-analog-output/arduino-code
AdafruitIO_Feed *HjemmeTemperatur = io.feed("HjemmeTemperatur");
  // start the serial connection
  Serial.begin(115200);
  // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // set up a message handler for the 'HjemmeTemperatur' feed.
  // the handleMessage function (defined below)
  // will be called whenever a message is
  // received from adafruit io.
  // wait for a connection
  while (io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  // grab the current state of the Temp-sensor
  current = analogRead(TEMP_PIN);
  // return if the value hasn't changed
  if (current == last)
    return;
  // save the current state to the 'HjemmeTemperatur' feed on adafruit io
  Serial.print("sending value -> ");
  Serial.println(current);
  HjemmeTemperatur->save(current);
  // store last Temp-sensor value
  last = current;
  delay(1000);
Thank you for helping me !
Loddepus
Re: error: 'handleMessage' was not declared in this scope
by abachman on Wed Jun 26, 2019 1:27 pm
hi Loddepus,
The code you pasted makes reference to "the handleMessage function". In the learn guide code, that function is defined in the block of code that looks like this:
// this function is called whenever an 'analog' message
// is received from Adafruit IO. it was attached to
// the analog feed in the setup() function above.
void handleMessage(AdafruitIO_Data *data) {
  // convert the data to integer
  int reading = data->toInt();
  Serial.print("received <- ");
  Serial.println(reading);
  analogWrite(LED_PIN, reading);
You can seen the whole example sketch by using the Arduino app File menu, going to Examples, finding the Adafruit_IO_Arduino library, and clicking on `adafruitio_09_analog_out`.
- adam b.
(PS - i edited your post to insert
[code][/code]
tags around the code sample)
abachman
by Loddepus on Thu Jun 27, 2019 2:57 am
Thank you abachman for guiding to the right tutorial. I have missed something there.
Loddepus
by Loddepus on Thu Jun 27, 2019 6:10 am
Hi again abachman.
Now I had time to look in the code you guided me to. To me it seems that I basicly miss this declaration:
void handleMessage(AdafruitIO_Data *data) {....
Is that right ?
The rest of my proposed code could be used with minor changes according to "Adafruit IO Analog Out Example" code ?
I wonder if the part of code that referes to ESP32 will work when I use NodeMCU-board ?
Loddepus
by brubell on Thu Jun 27, 2019 10:43 am
Is that right ?
It should work after you add the handlemessage function.
The code you posted uses the ESP8266 WiFi library, it won't work with an ESP32 as it'll need to use the ESP32 WiFi library.
brubell
by Loddepus on Thu Jun 27, 2019 3:56 pm
Hi brubell.
I did follow the "Adafruit IO Analog Out Example" exactly today , and it worked. I also added a servo and made to control it from my phone.
Thanks to both of you !
Loddepus
by calimacaco on Mon Jul 08, 2019 1:42 am
Im new in Adafruit,
I have a nodemcu ver.3 and a fingerprint, I use the liberira circuitpython, I follow the instructions to be able to enrrolar using:
https://learn.adafruit.com/adafruit-opt ... cuitpython
but when I download it to nodemcu it shows me the following error:
ValueError: Pin U0RXD in use
you can guide me
Thank you.
calimacaco
by brubell on Mon Jul 08, 2019 10:21 am
calimacaco wrote:Im new in Adafruit,
you can guide me
Thank you.
Please open an issue on the CircuitPython library for this sensor: https://github.com/adafruit/Adafruit_Ci ... int/issues
brubell
