MQTT Publish topic path variable
by davieswa123 on Mon Jul 08, 2019 5:30 am
Hello;
Is there a way to create a topic path to include a variable? It seems to only accept fixed #define values.
// Notice MQTT paths for Adafruit AIO follow the form: <username>/feeds/<feedname>
Adafruit_MQTT_Publish pubmessage = Adafruit_MQTT_Publish(&mqtt, MQTT_TOPIC_Variable "Gateway/"NodeID);
Any help or an example much appreciated.
W
davieswa123
Re: MQTT Publish topic path variable
by brubell on Mon Jul 08, 2019 10:20 am
The function signature for the Publish method follows the format:
bool Adafruit_MQTT::publish(const char *topic, uint8_t *data, uint16_t bLen, uint8_t qos) {
via https://github.com/adafruit/Adafruit_MQ ... T.cpp#L304
Since topic is a const char, it is immutable and therefore not able to be changed or set to a variable.
brubell
