Python Library Error, rgb_led example code
by Rev_02 on Mon Jul 08, 2019 9:49 am
I was following the rgb_led.py example code and the tutorial on the learning system, and when I run the code, I get the error that
AttributeError: 'Client' object has no attribute 'toRed'
when trying to convert the hex. I can code my own toRed function, but wondered if there was an easy fix that may have escaped the sample code?
Rev_02
Re: Python Library Error, rgb_led example code
by brubell on Mon Jul 08, 2019 10:31 am
The method calls within client.py were changed to to_red, to_blue.:
https://github.com/adafruit/Adafruit_IO ... ent.py#L64
I did not update this example after I modified the method signatures, I'll fix it.
UPDATE: This example has been fixed in `master`
brubell
by Rev_02 on Mon Jul 08, 2019 11:47 am
Ok brilliant, thank you
Rev_02
