ESP32: mqtt.readSubscription(5000) always returns 0
by avidNewb on Fri Jul 12, 2019 1:48 pm
Background:
I will post my code below. I am using an ESP32 and would like to connect Adafruit IO and Google Assistant. As a proof of concept I'm using the example code below. I have configured a feed exactly as per the example.
Problem:
MQTT connects and reports connected. However, "mqtt.readSubscription(5000)" always returns 0 and I cannot read the feed. It never enters the loop that a successful read would allow.
Example link:
https://iotdesignpro.com/projects/google-assistant-controlled-led-using-ESP32-and-adafruit-io
Code (with PII removed):
#include <WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#define WLAN_SSID       "XXXXXX"
#define WLAN_PASS       "XXXXXX"
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "XXXXXXX"
#define AIO_KEY         "XXXXXXXXXXXXXXXXXXXXXXXXXX"
int output=2;
WiFiClient client;     // Create an ESP8266 WiFiClient class to connect to the MQTT server.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);        // Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Subscribe LED_Control = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/LED_Control");
void MQTT_connect();
  Serial.begin(115200);
  delay(10);
pinMode(2,OUTPUT);
 // Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println();
 Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
  mqtt.subscribe(&LED_Control);
uint32_t x=0;
   MQTT_connect();
Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(5000))) {
    if (subscription == &LED_Control) {
      Serial.print(F("Got: "));
      Serial.println((char *)LED_Control.lastread);
       if (!strcmp((char*) LED_Control.lastread, "ON"))
        digitalWrite(2, HIGH);
      else
        digitalWrite(2, LOW);
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
 Serial.print("Connecting to MQTT... ");
uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println("MQTT Connected!");
avidNewb
