Linux and C/C++
Linux and C/C++
by pbuelow on Mon Jul 22, 2019 10:56 am
I have searched, but couldn't find anything using C/C++/Linux as keywords, so apologies if this has been asked before. I have a Onion.io board I want to use to send data to IO. But, the project is already done with C++ for all of the sensors, so writing it from scratch in python would be complicated to say the least.
Has anyone done a Paho or Eclipse MQTT implementation to connect to IO? I gave it a couple of test runs, but each the tests locked my account for 30 minutes, but didn't provide errors or any other information for my debug effort. I have currently given up for the REST/HTTPS API which works well enough, but mosquittopp gave me some advantages that I would love to have (return messaging like throttling is one, the C++ interface is another). I suspect it's a TLS problem, but don't have a good way to diagnose it.
Thanks for any help.
pbuelow
Re: Linux and C/C++
by brubell on Mon Jul 22, 2019 12:23 pm
pbuelow wrote:I have searched, but couldn't find anything using C/C++/Linux as keywords, so apologies if this has been asked before. I have a Onion.io board I want to use to send data to IO. But, the project is already done with C++ for all of the sensors, so writing it from scratch in python would be complicated to say the least.
Adafruit IO Python's MQTT Client uses Paho MQTT Python.
https://github.com/adafruit/Adafruit_IO_Python
Did the monitor page display any errors? Were you able to connect at all (did the client show up underneath Connected)
https://io.adafruit.com/monitor
There's a possibility that there's a connection issue, try connecting via the insecure port to diagnose if it's a SSL/TLS issue:
https://io.adafruit.com/api/docs/mqtt.h ... on-details
brubell
Re: Linux and C/C++
by pbuelow on Mon Jul 22, 2019 4:39 pm
Thank you, but Python would be a rewrite, otherwise this wouldn't be a problem.
I did not try insecure, didn't have time, but may go back. I had thought of it, but unfortunately only after. The monitor page showed me connect successfully, then disconnect later, but I never got an on_connect reply, and it was not using the name I supplied in the MQTT connect request, but rather a random string. There may not have been an error, but it wasn't telling me much and none of the callbacks were firing (on_error, on_connect, on_disconnect). the library prints didn't tell me much either, but I think I had an issue with those.
I'll try again over the weekend maybe, but am more interested in getting the new aquarium sensors up and running as fast as I can. Future improvements will come from that at some point.
pbuelow
Re: Linux and C/C++
by abachman on Mon Jul 22, 2019 5:15 pm
Hi pbuelow,
There's not currently any feature of IO's MQTT broker that will lock accounts for 30 minutes. Is it possible your device was trying to authenticate continuously after failing? We also disconnect clients that attempt to subscribe or publish to invalid/inaccessible MQTT topics. IO is pretty specific about valid topics. You can find them on feed pages and described in the documentation here: [url]https://io.adafruit.com/api/docs/mqtt.html#mqtt-topics
[/url]
I've not used a C++ MQTT client library outside of Arduino, but do you have any code samples with just the MQTT connection setup demonstrated?
- adam b.
abachman
Re: Linux and C/C++
by pbuelow on Mon Jul 22, 2019 9:21 pm
No, not right now. I can put it together quickly this weekend though and post it. I don't know that I was locked out, but submissions from my currently active client were no longer posting data for ~30 minutes. My first pass did have a retry, which is why I likely got "locked out" or whatever stopped my submissions from getting through.
I'll update this weekend.
pbuelow
Re: Linux and C/C++
by pbuelow on Mon Aug 26, 2019 10:04 pm
OK, it took a bit, but I got back to this tonight. I was able to put together a simple client using mosquittopp on an Ubuntu 19.04 machine. Works like a charm now that I follow the mosquittopp API more correctly AND I do the following when calling connect()
username_pw_set(m_user.c_str(), m_pass.c_str());
if (m_port == 8883)
    tls_psk_set(m_pass.c_str(), m_user.c_str());
connect_async(m_host.c_str(), m_port, keepalive);
loop_start();
You need the username_pw_set no matter what, which got me for a bit. However, when connecting via TLS over 8883, you MUST call the tls_psk_set() API as well. This isn't needed for open connections. I got tripped up by trying to use just one or the other for connections for a while.
Nice to know it works though, and it only took a few minutes to do write the framework using C++. I'll move this over to my Onion this weekend I suspect.
When using connect_async(), you should callback or signal a condition variable from on_connect to tell the system to it's allowed to loop() however you choose to do so. Calling loop() before on_connect() returns success or failure generally seems to result in inconsistent behavior looping and sending/receiving, though I am still just testing sends.
pbuelow
