Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Read button status on adafruit.io
by IoTAll on Tue Jul 23, 2019 7:03 am
Hi!
I am making a low power project when the feather is doing few tasks, sending data to and from Adafruit.io and then going to sleep for few hours.
I also have one on/off button on Adafruit.io dashboard and I get the change of status on the feather with the subscribe command through MQTT. This works well too.
I would like the project to read the on/off button status on the Adafruit.io dashboard when it wakes up.
Is this possible to do and if yes how?
IoTAll
Re: Read button status on adafruit.io
by IoTAll on Tue Aug 06, 2019 7:55 pm
Hi!
Does anyone know if this is possible?
IoTAll
by GrosPlombs on Wed Mar 04, 2020 10:06 pm
I found that you can "poll" a feed by writing a value to it. This is explained in the Adafruit IO MQTT API documentation under the topic Using the */get topic. Here is a link.
https://io.adafruit.com/api/docs/mqtt.html#adafruit-io-39-s-limitations.
You can define a new AdafruitIO_Feed and append /get to your feed name like this:
AdafruitIO_Feed *digital2 = io.feed("YOUR-FEED/get");
and write to it like this (\0 is a dummy value I chose):
digital2->save("\0");
This will trigger the feed to update your message.
You should be able to figure it out from the API docs because I was able too! :)
GrosPlombs
