Connected to Adafruit IO, but nothing else
Re: Connected to Adafruit IO, but nothing else
by brubell on Thu Aug 08, 2019 9:49 am
Lbkulinski wrote:Thank you for the info! I haven't had much time to look into it.
When I have the serial monitor already open, should I have to reset after I upload? That's the issue I am having at the moment. There are also question marks being printed when I open it. I can attached a screenshot if you need.
The question marks are caused by a mismatched baud rate. Could you paste your code below and attach a screenshot of the serial monitor too?
brubell
by Lbkulinski on Mon Aug 12, 2019 1:41 pm
Sorry for the late reply. I have been trying to resolve an issue with my Metro AirLift board.
I seems that I only get the question marks when I use my MacBook. I am currently using my Windows Desktop and am not having the same behavior. It isn't an issue, I was just curious. Here is my code:
#include "AdafruitIO_WiFi.h"
#include "AdafruitIO_Feed.h"
#include "AdafruitIO_Data.h"
#define USERNAME "Lbkulinski"
#define KEY "my-key"
#define SSID "my-ssid"
#define PASSWORD "my-password"
#define FEED_KEY "toggle"
#define CONNECTED_LED_PIN 13
#define LED_PIN 5
#define BAUD_RATE 9600
AdafruitIO_WiFi io(USERNAME, KEY, SSID, PASSWORD);
AdafruitIO_Feed* feed = io.feed(FEED_KEY);
  pinMode(CONNECTED_LED_PIN, OUTPUT);
  pinMode(LED_PIN, OUTPUT);
  Serial.begin(BAUD_RATE);
  while (!Serial);
  io.connect();
  while (io.status() != AIO_CONNECTED);
  digitalWrite(CONNECTED_LED_PIN, HIGH);
  Serial.println("Connected to Adafruit IO...");
  feed->onMessage(handleMessage);
  feed->get();
} //setup
  io.run();
} //loop
void handleMessage(AdafruitIO_Data* data) {
  int value = data->toPinLevel();
  digitalWrite(LED_PIN, value);
  if (value == HIGH) {
    Serial.println("HIGH");
  } else {
    Serial.println("LOW");
  } //end if
} //handleMessage
Lbkulinski
by brubell on Mon Aug 12, 2019 5:34 pm
Ok, make sure your serial monitor on your Mac's Arduino IDE is set to 9600 baud
brubell
by Lbkulinski on Mon Aug 12, 2019 9:07 pm
Here are two screenshots using 9600 baud. I believe I was using 115200 at one point and had the same issue. Is there a specific baud rate I should be using?
Screen Shot 2019-08-12 at 7.41.55 PM.png (267.54 KiB) Viewed 89 times
Screen Shot 2019-08-12 at 7.41.59 PM.png (264.67 KiB) Viewed 89 times
Lbkulinski
by brubell on Tue Aug 13, 2019 10:26 am
Try increasing the baud rate in your code, and on your monitor, to 115200 baud.
brubell
by Lbkulinski on Tue Aug 13, 2019 3:03 pm
It displays the same output. It’s odd that it only occurs on my Mac.
Lbkulinski
