Different Placement for io.run()
by 1CM69 on Fri Aug 09, 2019 2:45 pm
I thought I would share this little piece of info as it may help someone else.
I am using ESP-Now on my home IoT and there are a number of sensors (Masters) dotted around the house and they send their data back periodically via the wireless ESP-Now system to a receiving station (Slave).
The advantage is that the Masters do not need to connect to WiFi, thus cutting down on power usage, especially if running on a battery, the data transfer is very fast so they are only at max power for a fraction of a second before going back to DeepSleep and the cycle starts over again.
Because of how the coding for the Master & Slave needs to be constructed, it is very problematic to place the
io.run();
function call at the top of the main loop.
It took me a long time of trial & error but I finally got a working sketch, here is a small section
  if (millis()-heartBeat > 30000) {
    Serial.println("Waiting for ESP-NOW messages...");
    heartBeat = millis();
  if (haveReading) {
    haveReading = false;
    ThingSpeak.begin(client);
    wifiConnect();
    sendToThingSpeak();
    sendToAdafruit();
    delay(200);
    ESP.restart(); // <----- Reboots to re-enable ESP-NOW
void sendToThingSpeak() {
  ThingSpeak.writeField(myChannelNumber, 1, String(sensorData.temp), myWriteAPIKey);
void sendToAdafruit() {
  io.run();
  BedroomTempFeed->save(String(sensorData.temp));
you can see that I found placing the
io.run();
function call within another function that in turn is called from an 'if' statement inside the main loop, works without issue.
regards..,
Kirk
1CM69
