[SOLVED] BUG: Line chart setting pulldown doesn't track chan
by cjdshaw on Sun Aug 11, 2019 7:28 am
Repro steps:
Create a dashboard with a line chart, with history set to 24 hours
Save
Click the gear icon to edit, and change the line chart to 7 days using the on-chart pulldown
Save
The on-chart pulldown will read 24 hours, not 7 days. This means if you want to put it back to 24 hours, you have to change it away from that, then back
cjdshaw
Re: BUG: Line chart setting pulldown doesn't track changes
by cjdshaw on Sun Sep 15, 2019 12:40 pm
This bug appears to be fixed now. Thanks!
cjdshaw
