IO has stopped recording my feeds
by lunch_box on Tue Aug 13, 2019 10:16 pm
As the title says, IO has stopped recording my feeds. I can still see live data pop up when I have my feed page open, but nothing is being recorded.
Also, I keep getting an error saying that I don't have a username set, when I most assuredly do. I'm quite flummoxed.
Screen Shot 2019-08-13 at 10.05.54 PM.png (57.55 KiB) Viewed 297 times
Screen Shot 2019-08-13 at 10.10.17 PM.png (245.33 KiB) Viewed 297 times
lunch_box
Re: IO has stopped recording my feeds
by trackseven on Wed Aug 14, 2019 12:49 am
I had the same issue but with a bmp388 and a dht22 it kept saying update account settings
trackseven
by 00shano on Wed Aug 14, 2019 3:28 am
the same problem
00shano
by cjdshaw on Wed Aug 14, 2019 4:20 am
Same here. Depending on the scale of my line graph it works or doesn't
"2 days" seems to be the worst, with no data recorded since 18:35 UTC+1 yesterday
"24 hours" works fine
Most others have long gaps in them
Also, on mobile or XS layout, the title of the Dashboard gets cut off on the left
cjdshaw
by cjdshaw on Wed Aug 14, 2019 12:46 pm
Looks like it might be fixed. My data has started appearing, with a long gap
cjdshaw
by abachman on Wed Aug 14, 2019 1:04 pm
Hi all!
We recently updated the user interface on io.adafruit.com and along the way discovered a few bugs in older parts of the system. The occasional "no username" errors on requests and the missing aggregated data are both related to the deployment of the updated code.
The bugs are fixed, we updated the old parts, and we're currently catching up on the backlog of data for charting. No data was lost, but things got clunky on the view/reporting side of the system for a bit there, sorry about that.
No one should be getting the username error anymore and within the next 8 hours (catching up on the backlog is _slow_) everyone should have complete historical chart coverage.
- adam b.
abachman
by cjdshaw on Wed Aug 14, 2019 1:24 pm
Thanks. What happened to the ticker across the top of the dashboard screen which showed activity?
cjdshaw
by abachman on Wed Aug 14, 2019 2:44 pm
We're taking a look at that now. Thanks for the heads up.
- adam
abachman
by abachman on Wed Aug 14, 2019 5:17 pm
Found it and fixed it! There was a problem with the load order of the different page elements due to the new header.
You should see the soothing blue of data traffic on all your io.adafruit.com screens now.
- adam b.
abachman
by cjdshaw on Thu Aug 15, 2019 1:42 pm
Great. Thanks very much for the update!
- adam b.
cjdshaw
by kflmiami420 on Thu Aug 15, 2019 3:18 pm
abachman I keep getting errors
this code came from my pizero w dht22 script terminal window
 raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/temperature/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5b85ed0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
This code came from the Rapsberry Pi 4 1 gig that is sending cpu temp info to its own feed and dashboard
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw)
  File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 57, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 343, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in _validate_conn
    conn.connect()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 301, in connect
    conn = self._new_conn()
  File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 168, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0xb5723850>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
  File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 398, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/raspberrypi4/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5723850>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
  File "cpu_tempmon-2.py", line 33, in <module>
    aio.send(cpu_temp.key, temp)
  File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 154, in send_data
    return self.create_data(feed, payload)
  File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 254, in create_data
    return Data.from_dict(self._post(path, data._asdict()))
  File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 126, in _post
    data=json.dumps(data))
  File "/usr/lib/python3/dist-packages/requests/api.py", line 116, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3/dist-packages/requests/adapters.py", line 516, in send
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/raspberrypi4/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5723850>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
pi@raspberrypi4oneGB:~ $
I have a pi zero w with a dht22 and a bme280 both running and sending data to the adafruit io . The dht22 sends temperature & humidity
I also have a RPi 4 1gig sending cpu temp to its own feed and dash
to its own feeds and its own dashboard
I have the loop at 30 now it was at 15 seconds
The bme280 is also sending data to adafruit io . The bme280 sends temperature2 &pressure2&humidity2
i have the loop at 30 now it was at 15 seconds
What is the official max number this should be set at to prevent these errors of maximum tries
    Is it better to combine all scripts to one single one ?
kflmiami420
by abachman on Fri Aug 16, 2019 11:38 am
Hi kflmiami420,
This isn't an issue connected to the updates on Tuesday. It sounds like your device just can't connect to the internet, maybe? "Max retries exceeded with url" is an error from Python, not Adafruit IO.
Can you start a new thread on the forum here if you're still having trouble, please?
- adam b.
abachman
by kflmiami420 on Fri Aug 16, 2019 4:08 pm
will do thanks
kflmiami420
