Can we interrogate Adafruit.io for the latest data?
by IoTAll on Sat Aug 17, 2019 4:53 am
Hi!
I am wondering if it is possible to interrogate the Adafruit.io server on the lastest value received on a specific feed from for instance a M0 feather with Atwinc WiFi chip I am using.
Can be temperature feed received from another device, or an on/off button position status selected by the user, etc...
Is this possible?
Thank you!
IoTAll
Re: Can we interrogate Adafruit.io for the latest data?
by brubell on Mon Aug 19, 2019 10:25 am
You sure can!
If you're using the Adafruit IO HTTP API, you can use the Get Feed Data endpoint to query a feed for information such as latest value, or when it was created:
https://io.adafruit.com/api/docs/#get-feed-data
If you're using the Adafruit IO MQTT API it gets trickier. You'll need to use the */get topic (https://io.adafruit.com/api/docs/mqtt.h ... -get-topic) to retrieve the most recent value on the feed.
- brent r
brubell
by IoTAll on Mon Aug 19, 2019 1:47 pm
Thanks a lot for the help!
This works great!!
IoTAll
