How to blink LED while connecting to MQTT?
by stonez56 on Sun Aug 18, 2019 3:29 am
Thanks for the Adafruit.io service!
I have used voice Google Assistant to turn on light using IFTTT + Adafruit.io service without issues.
However, I would like blink LED or do other function loops while waiting mqtt.subscription.
How should I do that?
I tried to placed blinkLED() right after the loop(), but it only got executed every 1-2 second if MQTT is connected. If MQTT reconnect, then I have to wait more than 5-10 seconds.
In other words, blinkLED() will not get executed at the time I wanted.
Any recommendation?
blinkLED();
String feed_lastread;
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(5000))) {
    if (subscription == &light) {
      Serial.print(F("light:"));
      Serial.println((char *)light.lastread);
      feed_lastread = (char *)light.lastread;
      feed_lastread.trim(); //
      Serial.println("aven_light:" + feed_lastread); //for verifying the varialble
      // *** NOTICE: adafruit.io publishes the data as strings, not numbers!!!
      uint16_t reading = feed_lastread.toInt();
      if (reading > max_brightness) reading = max_brightness;
      Serial.print(F("Light last read: "));
      Serial.println(reading);
      changeBrightness(LEDpin, reading, prev_brightness );
      //remember this as prev brightness
      prev_brightness = reading;
stonez56
Re: How to blink LED while connecting to MQTT?
by brubell on Mon Aug 19, 2019 10:18 am
MQTT does need to ping the server (and reconnect if disconnected). You could call blinkLED from within the MQTT_connect function so you know when your hardware is reconnecting/pinging the server (it should be doing this at the top of your loop).
brubell
by stonez56 on Mon Aug 19, 2019 10:05 pm
brubell wrote:MQTT does need to ping the server (and reconnect if disconnected). You could call blinkLED from within the MQTT_connect function so you know when your hardware is reconnecting/pinging the server (it should be doing this at the top of your loop).
Thank you for the hint! I will give it a try.
Thank you,
Stonez56
stonez56
