Map not working
Map not working
by pcborges on Sun Aug 18, 2019 8:34 am
Hi, I set temp and humidity sensor data and a remote control led in my dashboard and everything works ok.
Map always show New York although I am half a world away...
What can I be doing wrong?
pcborges
Re: Map not working
by brubell on Mon Aug 19, 2019 10:12 am
pcborges wrote:Hi, I set temp and humidity sensor data and a remote control led in my dashboard and everything works ok.
The map dashboard block defaults to New York because that is where Adafruit is located :)
Locational data (such as latitude, longitude and elevation) is sent to Adafruit IO as Metadata, included with a value.
A way to do this would be creating an additional feed named Location and sending it latitude and longitude values using the Adafruit IO API Create Data endpoint: https://io.adafruit.com/api/docs/?shell#create-data
If you're not using the Adafruit IO HTTP API - could you please post your code below in
[code]code tags[/code]
brubell
Re: Map not working
by pcborges on Mon Aug 19, 2019 4:55 pm
Hi, I am using ESP32 with code as below:
How do I send lat/long to the MAP block?
#include "WiFi.h"
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#include "DHTesp.h"
#define  DHTpin 4    //D4 of ESP32 DevKit
/************************* Conexão WiFi*********************************/
#define WIFI_SSID       "mynet" // nome de sua rede wifi
#define WIFI_PASS       "mypass"     // senha de sua rede wifi
/********************* Credenciais Adafruit io *************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883   //secure=8883
#define AIO_USERNAME    "myusername" // Seu usuario cadastrado na plataforma da Adafruit
#define AIO_KEY         "mykey"       // Sua key da dashboard
/********************** Variaveis globais *******************************/
DHTesp     dht;
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
int led01 = 2; // pino do led
//Adafruit_dhtTemp dhtTemp = Adafruit_dhtTemp(); // instancia o objeto do sensor
long previousMillis = 0;
bool saveAll=true;     //true=salva tudo, false=só quando mudar valor
/****************************** Declaração dos Feeds ***************************************/
/* feed responsavel por receber os dados da nossa dashboard */
Adafruit_MQTT_Subscribe _led01 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/led01", MQTT_QOS_1);
/* feed responsavel por enviar os dados do sensor para nossa dashboard */
Adafruit_MQTT_Publish _dhtTemp = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/dhtTemp", MQTT_QOS_1);
Adafruit_MQTT_Publish _dhtHum  = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/dhtHum",  MQTT_QOS_1);
/* Observe em ambas declarações acima a composição do tópico mqtt
  --> AIO_USERNAME "/feeds/dhtTemp"
  O dhtTemp será justamente o nome que foi dado la na nossa dashboard, portanto o mesmo nome atribuido la, terá de ser colocado aqui tambem
/*************************** Declaração dos Prototypes ************************************/
void initSerial();
void initPins();
void initWiFi();
void initMQTT();
void initdht11();
void conectar_broker();
/*************************** Sketch ************************************/
  initSerial();
  initPins();
  initWiFi();
  initMQTT();
  initdht11();
  conectar_broker();
  mqtt.processPackets(5000);
  static float oldTemp=0,oldHum=0;
  bool mqttPostStatus;
  // Função responsável por ler e enviar o valor do sensor a cada 5 segundos
  unsigned long currentMillis = millis();
  if (currentMillis - previousMillis > 5000 && mqtt.connected()) {
    previousMillis = currentMillis;
    float t = dht.getTemperature();
    float h = dht.getHumidity();
    if (oldTemp!=t || saveAll){
      Serial.print("Temp: "); Serial.print(t); Serial.println("°C");
      mqttPostStatus = _dhtTemp.publish(t);
      if (mqttPostStatus) {
        Serial.print("Falha ao enviar o temp do sensor: ");
        Serial.println(mqttPostStatus);
      oldTemp=t;
    } else {
      Serial.println("Temp no change...");
    if (oldHum!=h || saveAll){
      Serial.print("Humidade: "); Serial.print(h); Serial.println("%");
      mqttPostStatus = _dhtHum.publish(h);
        Serial.print("Falha ao enviar o hum do sensor: ");
      oldHum=h;
    } else {
      Serial.println("Humidity no change...");
/*************************** Implementação dos Prototypes ************************************/
/* Conexao Serial */
void initSerial() {
  Serial.begin(115200);
/* Configuração dos pinos */
void initPins() {
  pinMode(led01, OUTPUT);
  digitalWrite(led01, LOW);
/* Configuração da conexão WiFi */
void initWiFi() {
  Serial.print("Conectando-se na rede "); Serial.println(WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("Conectado à rede com sucesso"); Serial.println("Endereço IP: "); Serial.println(WiFi.localIP());
/* Configuração da conexão MQTT */
void initMQTT() {
  _led01.setCallback(led01_callback);
  mqtt.subscribe(&_led01);
/* Inicialização do Sensor */
void initdht11() {
  dht.setup(DHTpin, DHTesp::DHT11); //for DHT11 Connect DHT sensor to GPIO 4
/*************************** Implementação dos Callbacks ************************************/
/* callback responsavel por tratar o feed do led01 */
void led01_callback(char *data, uint16_t len) {
  String state = data;
  if (state == "ON") {
    digitalWrite(led01, HIGH);
  } else {
  Serial.print("Led: "); Serial.println(state);
/*************************** Demais implementações ************************************/
/* Conexão com o broker e também servirá para reestabelecer a conexão caso caia */
void conectar_broker() {
  int8_t ret;
  uint8_t num_tentativas = 3;
  if (mqtt.connected()) {
    return;
  Serial.println("Conectando-se ao broker mqtt...");
  while ((ret = mqtt.connect()) != 0) {
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Falha ao se conectar. Tentando se reconectar em 5 segundos.");
    mqtt.disconnect();
    delay(5000);
    num_tentativas--;
    if (num_tentativas == 0) {
      Serial.println("Seu ESP será resetado.");
      while (1);
  Serial.println("Conectado ao broker com sucesso.");
pcborges
Re: Map not working
by brubell on Mon Aug 19, 2019 5:02 pm
If you switch to the Adafruit IO Arduino library, compatible with your ESP32, use the following example to send data to a feed named location.
https://github.com/adafruit/Adafruit_IO ... cation.ino
brubell
Re: Map not working
by pcborges on Mon Aug 19, 2019 5:40 pm
Hi, I checked it.
I was trying to port adafruitio_15_temp_humidity.ino but it does not compile.
Removed all references to hardware I do not posses and included the DHT11 (DHTesp.h) I am currently using
Says error compiling to ESP32.
Isn't there a way just to add some code in this my Sketch that is already working?
pcborges
Re: Map not working
by brubell on Mon Aug 19, 2019 5:51 pm
Could you please copy the error produced by the arduino ide and paste it here?
brubell
Re: Map not working
by pcborges on Mon Aug 19, 2019 5:59 pm
OK:
exit status 1
Erro compilando para a placa ESP32 Dev Module
// Adafruit IO temperatura & humidade Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-temperatura-and-humidade
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016-2017 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
//#include <Adafruit_Sensor.h>
//#include <DHT.h>
//#include <DHT_U.h>
#include "DHTesp.h"
// pin connected to DH22 data line
//#define DATA_PIN 2
// create DHT22 instance
//DHT_Unified dht(DATA_PIN, DHT22);
// set up the 'temperatura' and 'humidade' feeds
AdafruitIO_Feed *temperatura = io.feed("temperatura");
AdafruitIO_Feed *humidade = io.feed("humidade");
  // start the serial connection
  // wait for serial monitor to open
  while(! Serial);
  // initialize dht22
  //dht.begin();
  // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  //sensors_event_t event;
  //dht.temperatura().getEvent(&event);
  //float celsius = event.temperatura;
  //float fahrenheit = (celsius * 1.8) + 32;
  float celsius = dht.getTemperature();
  Serial.print("celsius: ");
  Serial.print(celsius);
  Serial.println("C");
  Serial.print("fahrenheit: ");
  Serial.print(fahrenheit);
  Serial.println("F");
  // save fahrenheit (or ) to Adafruit IO
  temperatura->save(celsius);
  //dht.humidade().getEvent(&event);
  float humidade = dht.getHumidity();
  Serial.print("humidade: ");
  Serial.print(humidade);
  // save humidade to Adafruit IO
  humidade->save(humidade);
  // wait 5 seconds (5000 milliseconds == 5 seconds)
  delay(5000);
config.h
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define AIO_USERNAME    "myuser" // Seu usuario cadastrado na plataforma da Adafruit
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
//   - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
//   - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
//   - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
//   - Feather M0 WiFi -> https://www.adafruit.com/products/3010
//   - Feather WICED -> https://www.adafruit.com/products/3056
//   - Adafruit PyPortal -> https://www.adafruit.com/product/4116
//   - Adafruit Metro M4 Express AirLift Lite -> https://www.adafruit.com/product/4000
//   - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
//   - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
//   - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
#define WIFI_SSID   "myuser"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// comment out the following lines if you are using fona or ethernet
#include "AdafruitIO_WiFi.h"
//#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE)
  // Configure the pins used for the ESP32 connection
  //#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
    // Don't change the names of these #define's! they match the variant ones
  //  #define SPIWIFI SPI
  //  #define SPIWIFI_SS 10  // Chip select pin
  //  #define NINA_ACK 9    // a.k.a BUSY or READY pin
 //   #define NINA_RESETN 6 // Reset pin
 //   #define NINA_GPIO0 -1 // Not connected
 // #endif
 // AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS, NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
//#else
  AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
//#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
//   - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
//   - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
// #include "AdafruitIO_Ethernet.h"
// AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
pcborges
Re: Map not working
by pcborges on Mon Aug 19, 2019 8:49 pm
Hi again.
I found that it is not compiling due to the following error:
C:\Users\pctbo\OneDrive\Documents\Arduino\libraries\Adafruit_IO_Arduino-master\src/AdafruitIO.h:23:31: fatal error: ArduinoHttpClient.h: No such file or directory
compilation terminated.
ESP32 uses HTTPClient.h
How can I solve this problem?
pcborges
Re: Map not working
by brubell on Tue Aug 20, 2019 11:08 am
Navigate to the Manage Libraries... option in the Sketch -> Include Library menu.
Then, enter ArduinoHttpClient into the search box, and click Install on the ArduinoHttpClient library option to install version 0.2.0 or higher.
brubell
Re: Map not working
by pcborges on Tue Aug 20, 2019 8:07 pm
Hi, thanks for your support.
I did the update as per your instruction, Now the compiler stops at:
C:\Users\pctbo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Client.h:32:17: note: virtual int Client::connect(const char*, uint16_t, int)
virtual int connect(const char *host, uint16_t port, int timeout) =0;
Again with Error compiling for the board ESP32 Dev Module.
Paulo
pcborges
Re: Map not working
by brubell on Thu Aug 22, 2019 9:58 am
Could you try downgrading the ESP32's firmware?
Instructions to do this are found on the following thread:
viewtopic.php?f=56&t=152781
brubell
Re: Map not working
by pcborges on Thu Aug 22, 2019 1:15 pm
Dear brubell, thanks for the support, now it compiles ok.
Back to the map problem.
I did find the following sample code:
AdafruitIO_Feed *gpslatlng = io.feed("gpslatlng");
and then inside loop:
  float GPSlat = (-22.893552);        // variable to store latitude
  float GPSlng = (-42.820837);        // variable to store longitude
  float GPSalt = (3);                 // variable to store altitude
  char gpsbuffer[30];                         // Combine Latitude, Longitude, Altitude into a buffer of size X
  char *p = gpsbuffer;                        // Create a buffer to store GPS information to upload to Adafruit IO                       </p><p>            dtostrf(Distance_To_Home, 3, 4, p);         // Convert Distance to Home to a String Variable and add it to the buffer
  p += strlen(p);
  //p[0] = ','; p++;
  dtostrf(GPSlat, 3, 6, p);                   // Convert GPSlat(latitude) to a String variable and add it to the buffer
  p += strlen(p);
  p[0] = ','; p++;
  dtostrf(GPSlng, 3, 6, p);                   // Convert GPSlng(longitude) to a String variable and add it to the buffer
  p += strlen(p);
  p[0] = ','; p++;
  dtostrf(GPSalt, 2, 1, p);                   // Convert GPSalt(altimeter) to a String variable and add it to the buffer
  p += strlen(p);
  gpslatlng->save(gpsbuffer);
It is likely wrong and the map is blank.
The link you sent previously does not seem to match my way of coding.
Thanks in advance.
pcborges
Re: Map not working
by pcborges on Thu Aug 22, 2019 1:59 pm
Hi again.
Sorted out...
I was looking into the wrong tab on the link you passed "https://io.adafruit.com/api/docs/?cpp#create-data"
Now looking into the Arduino tab I got the right code.
Works great.
pcborges
Re: Map not working
by pcborges on Thu Aug 22, 2019 2:09 pm
Now, to complement:
In my old code I had a button to send "ON" or "OFF" to control a LED on my ESP32
For that I had a subscribe:
and...
How do I subscribe in this new scenario?
Thanks in advance
Paulo
pcborges
