processPackets(5000) does not work in my code anymore
by goatcreek on Fri Aug 23, 2019 4:45 pm
Previously i had no problem with the MQTT processPackets() it ran my setCallbacks as expected.
Here is the working code snippets:
#include <ESP8266WiFi.h>
#include <WiFiUDP.h>
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_Client.h>
All my #define are correct in this block, but I omitted them for security purposes
there may be some missing variable initialisations but they are all correct as well.
struct clockStorage {
  uint8_t lastHour;
  uint8_t lastMinute;
  uint8_t cycleCount = 0;
  bool lockState = false; // is door locked?
} clockCurrent;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_USERNAME, AIO_KEY);
// set up the time, doorbtn, and lockbtn feed
Adafruit_MQTT_Subscribe timefeed = Adafruit_MQTT_Subscribe(&mqtt, "time/seconds");
Adafruit_MQTT_Subscribe doorBtn = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/doorbtn", MQTT_QOS_1);
Adafruit_MQTT_Subscribe lockBtn = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/lockbtn", MQTT_QOS_1);
Adafruit_MQTT_Publish doorBtn_get = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/doorbtn/get");
Adafruit_MQTT_Publish lockBtn_get = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/lockbtn/get");
  // attach a handler to the time feed
  timefeed.setCallback(check_MQTT_Time);
  // attach a new message handler
  doorBtn.setCallback(door_Button);
  lockBtn.setCallback(lock_Button);
    if (MQTT_connect()) { // MQTT is Connected
      // GET CURRENT VALUES FROM AIO
      mqtt.subscribe(&lockBtn);
      mqtt.subscribe(&doorBtn);
      mqtt.subscribe(&timefeed);
      // read subscriptions and run 'setCallBack()'
      mqtt.processPackets(5000);
void check_MQTT_Time(uint32_t current) {
  // Wifi, retrieving time from MQTT
  uint32_t mqttTime = current;
  // adjust to local time zone
  current += (timeZone * 60 * 60);
  int curr_hour = (current / 60 / 60) % 24;
  int curr_min  = (current / 60 ) % 60;
  // int curr_sec  = (current) % 60;
    sprintf(currentTime, "MQTT: %02d:%02d", curr_hour, curr_min);
    SERIALMON.println(currentTime);
   clockCurrent.lastHour = curr_hour;
   clockCurrent.lastMinute = curr_min;
  if (DEBUG) {
// Button Handler
void door_Button(char *doorTemp, uint16_t len) {
  // Parse doorBtn messages
  if (DEBUG) {
    SERIALMON.print(F("doorbtn -"));
    SERIALMON.println(doorTemp);
  if (strcmp(doorTemp, test) == 0)
    doorCommand = 0;
  } else {
    doorCommand = 1;
// Button Handler
void lock_Button(char *lockTemp, uint16_t len) {
  // Parse lockBtn messages
  if (DEBUG) {
    SERIALMON.print(F("lockBtn -"));
    SERIALMON.println(lockTemp);
  if (strcmp(lockTemp, test) == 0)
    clockCurrent.lockState = 0;
  } else {
    clockCurrent.lockState = 1;
bool MQTT_connect() {
  // Function to connect and reconnect as necessary to the MQTT server.
  // Should be called in the loop function and it will take care if connecting.
  // Requests doorBtn, lockBtn
  // Sets doorCommand, clockCurrent.lockState
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return true;
  SERIALMON.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    SERIALMON.println(mqtt.connectErrorString(ret));
    SERIALMON.println("Retrying MQTT connection in 10 seconds...");
    mqtt.disconnect();
    delay(10000);  // wait 10 seconds
    retries--;
    if (retries == 0) {
      // basically die and wait for WDT to reset me
      SERIALMON.println(F("Cannot Connect to MQTT"));
      return false;
  SERIALMON.println("MQTT Connected!");
  doorBtn_get.publish(0);
  lockBtn_get.publish(0);
  return true;
So all of that code worked, the correct time was retrieved, the doorBtn and lockBtn states were retrieved. now I have attempted to add it into my larger source and modified a few of the processes to make it more readable and easier to modify for me. And now it doesn't worrk. See the following for the changes. Note that I have only included the snippets that have changed, not all of the setup code above that didnt change at all.
    if (MQTT_connect()) { // MQTT is Connected - get NTP time and door switches
      while (!MQTT_Feeds());
      yield();
boolean MQTT_Feeds () {
  SERIALMON.println(F("MQTT_Feeds Start"));
  mqtt.ping();
  return true;
void MQTT_Time(uint32_t current) {
  SERIALMON.println(F("check_MQTT_Time Start"));
  if (curr_min > (clockRtc.lastMinute + 5)) {
    SERIALMON.println(F("Check_MQTT_Time: RTC has lost +5 minutes, updating with MQTT Time"));
    rtcCheck(mqttTime);
  if (DEBUG) {
    sprintf(currentTime, "Check_MQTT_Time : %02d:%02d", curr_hour, curr_min);
I can post the code in entirety if needed, but those are the relevant pieces. Again if there are any missing variable init's or other values I assure you they are set properly. The rest of my code works great.
And here is my serial monitor output with the new code:
Starting Coop Monitor
Connecting to WiFi.......... WiFi connected.
Loop Start
sensor_Data start
doorState0>>doorState1
0>>0
rtcCheck : RTC: 16:27
MQTT_Connect: Connecting to MQTT...
MQTT_Connect: MQTT Connected!
MQTT_Feeds Start
check_Wake Start
Back to Sleep
Door Command: 255
Lock State: 0
door_Control Start
Door is Unlocked
Exiting door_control function
MQTT_Update Start
ESP8266 in sleep mode : (seconds) 3600
I can see the MQTT_connect() is working fine. And it runs the MQTT_feeds(). It just doesnt seem to run the setCallbacks upon processPackets(). But it did prior to this move to a seperate function called outside of the loop(). Also of note you may see at the bottom of the Serial monitor "MQTT_Update Start" that is a function I didnt show, but it properly updates the MQTT and I can verify that by logging in to io.adafruit. I can switch back to my old method, but I don't see why this would work. Any ideas?
Thanks for looking
goatcreek
