Getting an error uploading to Adafruit IO
by kflmiami420 on Sat Aug 24, 2019 2:31 am
Temp=29.8*C Humidity=37.2%
Temp=29.8*C Humidity=37.4%
Temp=29.7*C Humidity=37.2%
Temp=29.6*C Humidity=37.1%
Temp=29.5*C Humidity=36.5%
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 160, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw)
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/util/connection.py", line 57, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.5/socket.py", line 733, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 603, in urlopen
    chunked=chunked)
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 344, in _make_request
    self._validate_conn(conn)
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 843, in _validate_conn
    conn.connect()
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 316, in connect
    conn = self._new_conn()
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 169, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0xb5cfbd90>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
  File "/home/pi/.local/lib/python3.5/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 641, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/home/pi/.local/lib/python3.5/site-packages/urllib3/util/retry.py", line 399, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/temperature/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5cfbd90>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
  File "temp_humidity.py", line 35, in <module>
    aio.send(temperature_feed.key, str(temperature))
  File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 154, in send_data
    return self.create_data(feed, payload)
  File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 254, in create_data
    return Data.from_dict(self._post(path, data._asdict()))
  File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 126, in _post
    data=json.dumps(data))
  File "/home/pi/.local/lib/python3.5/site-packages/requests/api.py", line 116, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/home/pi/.local/lib/python3.5/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/home/pi/.local/lib/python3.5/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/home/pi/.local/lib/python3.5/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/home/pi/.local/lib/python3.5/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/temperature/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5cfbd90>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
pi@raspberrypize11:~ $
Can some one help me out
Raspberry Pi Zero w - DHT22 sensor and bme280 sensor . Debian Buster
this is the python code for my setup
#emdht22.py'
import time
import Adafruit_DHT
from Adafruit_IO import Client, Feed
DHT_READ_TIMEOUT = 35
DHT_DATA_PIN = 10
ADAFRUIT_IO_KEY = '0d23xxxxxxxxxxxxxxxxxxxxxxxxx'
ADAFRUIT_IO_USERNAME = 'miamihurricaneschain'
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
temperature_feed = aio.feeds('temperature')
humidity_feed = aio.feeds('humidity')
dht22_sensor = Adafruit_DHT.DHT22
while True:
    humidity, temperature = Adafruit_DHT.read_retry(dht22_sensor, DHT_DATA_PIN)
    if humidity is not None and temperature is not None:
        print('Temp={0:0.1f}*C Humidity={1:0.1f}%'.format(temperature, humidity))
        # Send humidity and temperature feeds to Adafruit IO
        temperature = '%.2f'%(temperature)
        humidity = '%.2f'%(humidity)
        aio.send(humidity_feed.key, str(humidity))
    else:
        print('Failed to get DHT22 Reading, trying again in ', DHT_READ_TIMEOUT, 'seconds$
    time.sleep(DHT_READ_TIMEOUT)
kflmiami420
Re: Getting an error uploading to Adafruit IO
by be80be on Sat Aug 24, 2019 10:40 am
Your losing internet connection
be80be
