IFTTT - GPS Location
by bernd_d on Sat Aug 24, 2019 5:54 am
I'm new here and really like Adafruit IO. I send LoraWAN sensor data and currently visualize them in Dashboards which works great.
Now I tried to get GPS location information into IO. The data is send from TheThingsNetwork --> IFTTT --> Adafruit IO (like for the other sensors).
However it seems I missed somewhere to format the GPS data the right way within IFTTT. I see the correct GPS lat and lon information in the feed table.
I hope I didn't miss it in the forum search somewhere...
Currently the value field in the feed table looks like this (replaced the GPS coordinates with '1'):
value : 0, lat : 11.1111, lon : 1.1111
In the next column it seems that a location is recognized as there is a "Location" column in the feed table with a "view" button.
If I click the button I see an ID. However when I create a map block within a Dashboard it isn't populated with the feed values...but it feels I'm close to it ;-)
My question is what is the right way to format the data within IFTTT so that Adafruit IO correctly recognizes the data as GPS information and the map block can visualize it ?
Would appreciate your thoughts or a pointer in the right direction.
Best regards, Bernd
bernd_d
Re: IFTTT - GPS Location
by brubell on Mon Aug 26, 2019 9:42 am
It seems like you're sending everything correctly. Could you take a screenshot of your Feed page and post it below?
brubell
by bernd_d on Mon Aug 26, 2019 1:23 pm
Thank you for your reply
brubell wrote:It seems like you're sending everything correctly. Could you take a screenshot of your Feed page and post it below?
I attach a screenshot of my feed page and the popup window that appears when pressing "view" in the location column.
Regards,
Bernd
Popup window when pressing "view" in the feed page
Screenshot of feed page with location column
bernd_d
by brubell on Tue Aug 27, 2019 9:27 am
It seems like you're sending the location in the value field. The map block looks for location as metadata in the location field, highlighted below in red:
Here's an example of a feed with the location field populated correctly:
IFTTT should be sending GPS location as optional metadata, along with the value:
# Send new data with a value of 42 and include optional location metadata
curl -H "Content-Type: application/json" -d '{"value": 42, "lat": 23.1, "lon": "-73.3"}'  -H "X-AIO-Key: {io_key}" https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data
Reference: https://io.adafruit.com/api/docs/#create-data
Could you post the IFTTT setup?
brubell
by bernd_d on Tue Aug 27, 2019 10:41 am
Thanks for the working sample. Attached the IFTTT setup as per GUI.
Thanks for you support!
Regards, Bernd
bernd_d
by brubell on Wed Aug 28, 2019 9:53 am
Seems like the IFTTT integration sends everything to the value field instead of separating it. Wanna see if using https://zapier.com makes it possible to send metadata as well as the value field?
brubell
by bernd_d on Fri Aug 30, 2019 8:14 am
brubell wrote:Seems like the IFTTT integration sends everything to the value field instead of separating it. Wanna see if using https://zapier.com makes it possible to send metadata as well as the value field?
Thank you for the additional option with zapier, but I'd prefer not to use another service ;-)
Maybe it is just the wrong data format or keywords I used within ifttt ? Any specific keywords on the IO side that are necessary to fill the location column?
bernd_d
by brubell on Fri Aug 30, 2019 10:22 am
IFTTT may be only filling the value field, instead of sending extra fields (for the location) to IFTTT such as lat/lon/ele.
brubell
by bernd_d on Sat Sep 28, 2019 11:57 am
It's been awhile now but finally I was able to give Zapier a try. Really great interface and great options compared to IFTTT. I like it. ;-)
However I still struggle in getting the gps coordinates into the io dashboard location column. I was able to connect zapier to adafruit but I see the same results as if they come via IFTTT...
I'd appreciate any hints for data formatting within Zapier to make Adafruit recognize the coordinates as "location" not as "value"...
Bernd
bernd_d
by mharmon12 on Mon Sep 07, 2020 10:12 pm
I'm using
AdafruitIO_Feed *AIO_feed = io.feed( "myFeedInAdafruitIO");
AIO_feed->save( val, lat, lon, ele );
Where
val is an integer
lat, lon & ele are double.
When I tried anything else then my information ALL went to the value as in your example.
Try just sending each value comma separated.
mharmon12
by adafruitguy on Thu Oct 08, 2020 8:56 am
I'm having a similar challenege via ifttt placing all data in the "Value".
From my IFTTT setup...
Here's my IFTTT Setup
ifttt data.png (29.91 KiB) Viewed 211 times
Feed showing up on Adafruit.io under Location "View"...
Location Data Showing as "View"
Screen Shot 2020-10-08 at 8.41.18 AM.png (24.09 KiB) Viewed 211 times
And it looks like everything is in the Value field...
Value Field Only
io example.png (64.28 KiB) Viewed 211 times
Anyone have some more suggestions? My data is originating on The Things Network, and I would like to log and display on a map via Adafruit.io
adafruitguy
by adafruitguy on Sat Oct 10, 2020 8:55 am
IFTTT allows a web request via Webhooks. If I use this instead of the IFTTT Adafruit integration might I be able to feed location data into the proper place, instead of everything showing up in Value?
IFTTT Webhooks POST
Screen Shot 2020-10-10 at 8.38.08 AM.png (138.39 KiB) Viewed 190 times
What would I use for the URL and where would I apply my username and Key?
X-AIO-Key= somanysecrets in the body?
adafruitguy
by adafruitguy on Sun Oct 11, 2020 9:44 am
It looks like success is possible using IFTTT to get GPS data into the location fields...
Instead of using the IFTTT Adafruit service for you "then that" ingredient, add: "Webhooks", "Make a web request" with the following...
IFTTT Make a Web Request
Screen Shot 2020-10-11 at 9.24.03 AM.png (156.24 KiB) Viewed 164 times
https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data?x-aio-key={io_key}
Using your own: {username}, {feed_key}, and {io_key}
This yields the desired results...
Data in the desired location fields
Screen Shot 2020-10-11 at 9.24.33 AM.png (31.88 KiB) Viewed 164 times
adafruitguy
by bernd_d on Mon Oct 12, 2020 9:18 am
adafruitguy wrote:It looks like success is possible using IFTTT to get GPS data into the location fields...
@adafruitguy - You are the guy!! Thanks for sharing this. This works ! Adafruit offers the URL by copying the adafruit feed URL that is automatically generated into the webrequest URL.
bernd_d
