Connection is not stablishing between my NodeMCU and Adafrui
by Sanjay123 on Tue Aug 27, 2019 2:53 am
Hii, I am preparing a "Voice Control Automation System using Google Assistant". The buttons in Adafruit IO are switching in voice comand but my NodeMCU is not responding. Still my NodeMCU is connected via hotspot of my phone.
I am also sending the code. If something incorrect in it, so please guide me.
I hope you will tell me the solution of my problem as soon as possible.
Thank you.
MARK 1.txt
(3.25 KiB) Downloaded 13 times
Sanjay123
Re: Connection is not stablishing between my NodeMCU and Ada
by brubell on Tue Aug 27, 2019 9:20 am
When you connect your NodeMCU, does it appear on the monitor page as an active connection?
http://io.adafruit.com/monitor
Could you please paste your code in
[code]code tags[/code]
below? Thanks!
brubell
