[SOLVED] Bridging Mosquitto MQTT to io.Adafruilt.com
Re: [SOLVED] Bridging Mosquitto MQTT to io.Adafruilt.com
by dom106 on Sat May 30, 2020 11:14 am
Dear,
I think this time this solved. I found the generic mosquitto.conf file which mix both secure and unsecure port:
https://gist.githubusercontent.com/tdac ... ridge.conf but still received the following error:
"MQTT ERROR: raspberrypi.adafruit-light-sensor xxx.xxx.xxx.xxx PUBLISH to topic `/feeds/exp.ch5` rejected, in {username}/{type}/{key} topics for shared resources, {username} may not be blank"
At least this proves the connection itself is ok but something is wrong in the topic mapping. Eventually, I relalized I was sending out my "/feeds/exp.ch5" but the username was missing at Adafruit; So I rewrote the topic line as follow and it eventually worked :) :
topic /feeds/exp.ch5 out 0 MyUserName
That way, Adafruit will receive the correct topic name, i.e: MyUserName/feeds/exp.ch5.
Many thanks for your advices,
dom106
