How do you pull Data from Feed and use as Var in loop?
by dsblock19 on Sun Sep 01, 2019 3:03 am
I'm following the subscribe code example and supplementing it with info from io docs here: https://io.adafruit.com/api/docs/mqtt.html#using-the-get-topic.
I'm trying to get the last data from a feed then use it as a variable for comparison in an if function.
That part of code is:
    io.run();
    unsigned int SW = hxweight->get();
    //Send Start Weight
    Serial.print("sending SW-> ");
    Serial.println(SW);
    startweight->save(SW);
IT just always sends a 1.
It's a long code so let me know if I need to post more. My pre-setup and setup is exactly like the example but multiple feeds.
dsblock19
Re: How do you pull Data from Feed and use as Var in loop?
by brubell on Tue Sep 03, 2019 1:55 pm
Could you please post your complete code?
brubell
