Customer needs version of this board, but with 12 or more in
by dan_rapp on Thu Sep 05, 2019 8:46 pm
To Adafruit Support Team:
The customer needs a version of this audio FX sound board p/n 2217 (or p/n 2133) that includes more than
11 input Triggers for buttons or switches; the customer needs at least 12 -- if not more. I wasn't able to find
such, but wanted to verify with you just in case I missed something.
Can you help us with this?
Dan Rapp
Technical Support
Mouser Electronics
(800) 346-6873
(817) 804-3800
www.mouser.com
QAF187B
dan_rapp
Re: Customer needs version of this board, but with 12 or mor
by adafruit_support_mike on Fri Sep 06, 2019 12:30 am
The VS1000 (the main chip in the FX Board) only has 11 inputs, so there's no way to increase the number of hardware trigger pins.
The VS1000 also have a Serial control interface though, so they can use a microcontroller for input and control options the FX Board can't do on its own.
A small microcontroller board like the Trinket M0 can talk to a row of I2C GPIO expanders like the MCP23017 (16 inputs x 8 pin-selectable I2C addresses = 128 inputs), then tell the FX Board what sounds to play.
Our tutorial for the FX Board has more information about the Serial interface:
https://learn.adafruit.com/adafruit-aud ... io-control
and we have code support for the MCP23017 in C and CircuitPython.
Another option would be to brute-force the solution by using more than one FX Board and separate speakers.
