[SOLVED] dashboard q. decimal places and color coding
by jimk123 on Mon Sep 09, 2019 3:25 pm
I am using some gauge blocks on my dashboard to show temp and humidity. Is there a way to specify the number of decimal positions ? currently its shows two decimal points but I would like to only display one , e.g. 72.3 vs 72.33 for certain feeds and two decimal points for others.
Also when assigning high and low values it changes the color from blue to yellow. is there a way to pick a different color ? On a temp gauge was thinking if I could specify red it would stand out more if it exceeded the high or low range ?
is there a place in the forums where users could suggest future enhancements to the dashboard ?
thanks
jimk123
Re: dashboard q. decimal places and color coding
by mikeysklar on Mon Sep 09, 2019 8:37 pm
Hello jimk123,
You can use the dashboard config.ini to specific how many decimal_digits to display. Here is an example config.
https://learn.adafruit.com/raspberry-pi ... dafruit-io
[slider]
type = SevenSegmentWidget
address = 0x74
decimal_digits = 0
[humidity]
address = 0x76
decimal_digits = 2
[temp]
address = 0x71
decimal_digits = 1
The "Indicator blocks" let you pin on/off and range colors using "Block settings".
https://io.adafruit.com/blog/notebook/2 ... rd-blocks/
mikeysklar
by jimk123 on Mon Sep 09, 2019 8:59 pm
Thanks for the reply, those links seem to be for the raspberry pi. I am using a esp8266 to upload feeds for temp and humidity and then using a browser to go to io.adafruit.com and viewing a dashboard. Not sure I understand how the config.ini is used ?
jimk123
by brubell on Tue Sep 10, 2019 9:32 am
jimk123 wrote:Thanks for the reply, those links seem to be for the raspberry pi. I am using a esp8266 to upload feeds for temp and humidity and then using a browser to go to io.adafruit.com and viewing a dashboard. Not sure I understand how the config.ini is used ?
The config.ini is out of date @mikeysklar.
@jimk123: You can't specify decimal places for the gauge, you'd need to truncate the value (72.33 to 72.3) in your code, before sending it to Adafruit IO.
Not currently
Post up in this thread - IO Devs read it frequently:
viewtopic.php?f=56&t=130408
brubell
by jimk123 on Tue Sep 10, 2019 7:59 pm
Thank you !
jimk123
cron
