Adafruit IO show me the temperature
by Zagorov93 on Sun Sep 15, 2019 3:22 pm
Hello
I read many things in the forum but i can't find how to clear this mistake which the stream window is giving me :
2019/09/15 10:11pmerrorspublication to Relay4Temp failed: publish is not authorized, user is temporarily blocked.
I will post you the code if you can help me
#include <DHTesp.h> //
  //Google Assistant Home Automation
  #include <Arduino.h> //
  #include <WiFi.h> //
  #include <analogWrite.h>
  #include "Adafruit_MQTT.h"
  #include "Adafruit_MQTT_Client.h"
  #define doorSwitch        2
  #define Relay1            5
  #define Relay2            18
  #define Relay3            19
  #define WLAN_SSID       "Galaxy S8+"             // Your SSID
  #define WLAN_PASS       "puux8218"        // Your password
/** *********** DHT11 - begin ************************** */
/** Initialize DHT sensor */
DHTesp dht;
/** Task handle for the light value read task */
TaskHandle_t tempTaskHandle = NULL;
/** Pin number for DHT11 data pin */
// Този пин трябва да промениш
// в зависимост от твоето свързване
int dhtPin = 4;
// Това са променливите в които се съхранява
// измерената температура и влажност
float Temperature = 0; // Температура
float Humidity =0;     // Влажност
// Initialize temperature sensor
   Извиква се в void setup() {}
void initDHT11() {
  dht.setup(dhtPin, DHTesp::DHT11);
// Reading temperature and humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
void readTempAndHumidity() {
  TempAndHumidity lastValues = dht.getTempAndHumidity();
 Temperature = lastValues.temperature;
 Humidity =lastValues.humidity;
/** *********** DHT11 end ************************** */
  /************************* Adafruit.io Setup *********************************/
  #define AIO_SERVER      "io.adafruit.com" //Adafruit Server
  #define AIO_SERVERPORT  1883
  #define AIO_USERNAME    "Zagorov93"            // Username
  #define AIO_KEY         "AIO_KEY"   // Auth Key
  //WIFI CLIENT
  WiFiClient client;
  Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT,
  AIO_USERNAME, AIO_KEY);
  Adafruit_MQTT_Publish AC_off = Adafruit_MQTT_Publish(&mqtt,
  AIO_USERNAME "/feeds/Relay2"); // Feeds name should be same everywhere
  Adafruit_MQTT_Subscribe Oven = Adafruit_MQTT_Subscribe(&mqtt,
  AIO_USERNAME "/feeds/Relay1");
  Adafruit_MQTT_Subscribe AC = Adafruit_MQTT_Subscribe(&mqtt,
  Adafruit_MQTT_Subscribe Light1 = Adafruit_MQTT_Subscribe(&mqtt,
  AIO_USERNAME "/feeds/Relay3Slider");
// ------- Температура и влажност ----------------
  Adafruit_MQTT_Publish TempHum = Adafruit_MQTT_Publish(&mqtt,
  AIO_USERNAME "/feeds/Relay4Temp");
  void MQTT_connect();
    /* Задаване на скорост на трансфер на данни между
    серийният порт на компютъра и ESP32 */
    Serial.begin(115200);
   // Инициализация на DHT11
   initDHT11();
    //Дефиниране на типа входно/изходни пинове
    pinMode(doorSwitch, INPUT);
    pinMode(Relay1, OUTPUT);
    pinMode(Relay2, OUTPUT);
    pinMode(Relay3, OUTPUT);
    // Свързване към безжичната мрежа.
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(WLAN_SSID);
    WiFi.begin(WLAN_SSID, WLAN_PASS);
    //Изчакване на връзка
    while (WiFi.status() != WL_CONNECTED) {
      delay(500);
      Serial.print(".");
    //Извеждане на информация относо свързаността
    Serial.println();
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
    //Създаване на връзка за предаване на данни
    mqtt.subscribe(&Light1);
    mqtt.subscribe(&AC);
    mqtt.subscribe(&Oven);
// Създаване на връзка за предаване на данни за температура и влажност
 //   mqtt.publish(&TempHum);
  // Измерване на температурата и влажността
  readTempAndHumidity();
  MQTT_connect();
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(5000))) {
    if (subscription == &Oven) {
      Serial.print(F("Oven Got: "));
      const char* OvenCommand = (const char *)Oven.lastread;
      Serial.println(OvenCommand);
      if (strcmp(OvenCommand, "ON") == 0){
          digitalWrite(Relay1, HIGH);
      } else {
          digitalWrite(Relay1, LOW);
      Serial.println("Done");
    if (subscription == &AC) {
      Serial.print(F("AC Got: "));
      const char* ACCommand = (const char *)AC.lastread;
      Serial.println(ACCommand);
      if (strcmp(ACCommand, "ON") == 0){
          digitalWrite(Relay2, HIGH);
      } else {
          digitalWrite(Relay2, LOW);
    if (subscription == &Light1) {
      Serial.print(F("Light Got: "));
      Serial.println((char *)Light1.lastread);
      uint8_t Light1_slide = atoi((char *)Light1.lastread) * 255/100;
      Serial.println(Light1_slide);
      analogWrite(Relay3, Light1_slide);
// --------------- Температура и влажност ---------------------
 if (subscription == &TempHum) {
  Serial.println("Temperature: " + String(Temperature,0));
  Serial.println("Humidity: " + String(Humidity,0));
    Serial.println("Break");
  if (digitalRead(Relay2) == HIGH ) {
    check_door();
  // String sendStr = String("{ \"Temperature\": ") + String(Temperature,0) + String(",\"Humidity\":") + String(Humidity,0) + String("}");
 // String sendStr = "{\"Temperature\":123,\"Humidity\":456}";
    String webString = "{\"Temperature\":123}";
  //(username)/groups/(group name or key)
   Serial.println(webString);
  char buffer[200];
  uint8_t len = webString.length();
  webString.toCharArray((char *)buffer,len);
  //   mqtt.sendPacket(buffer,len);
  // mqtt.publish("esp32/temperature", tempString);
   // mqtt.publish("Zagorov93/Feeds/Relay4Temp", buffer); // towa e imeto Relay4Temp Грешката е в този текст
    mqtt.publish("Relay4Temp", buffer);
    // Виж този пример и се опитай да го направиш по него
//payload formation begins here
String payload ="{";
payload +="\"Temp\":"; payload +=10; payload +=",";
payload +="\"Humi\":"; payload +=20;
payload +="}";
char attributes[1000];
payload.toCharArray( attributes, 1000 );
client.publish("test", attributes); //topic="test" MQTT data post
void check_door() {
  if(digitalRead(doorSwitch) != HIGH) {
    delay(10000);
      AC_off.publish("OFF");
      digitalWrite(Relay2,LOW);
void MQTT_connect() {
  int8_t ret;
  //Проверка дали вече е осъществена връзка
  if (mqtt.connected()) {
    return;
  //Осъществяване на връзка
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { //Връща 0, ако връзката се осъществи
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);
    retries--;
    if (retries == 0) {
      while (1);
  Serial.println("MQTT Connected!");
Regards.
Zagorov93
Re: Adafruit IO show me the temperature
by brubell on Mon Sep 16, 2019 9:18 am
Hi Zagorov93,
From the IO Website, are you able to update/add new data to the Relay2 feed?
brubell
