Battery Powered ESP01 Controlled via Alexa
by voodoo28 on Tue Sep 24, 2019 10:19 am
Hi all, I have been working on a Smart Blinds project at home with my blinds.. I currently have an ESP01s connected to my motorized blinds, which is powered by the battery within the blinds. At the moment I can control my blinds via voice commands through ALEXA, however, since the ESP is connected to the battery of the blind it drains the battery within a day.
My question: is it possible to utilized the Sleep Modes of the ESP01s in order to conserve power while still maintaining a connection to ALEXA?
What are my options?
Thanks in advance.
Peter
voodoo28
Re: Battery Powered ESP01 Controlled via Alexa
by brubell on Tue Sep 24, 2019 10:28 am
If you need to maintain a connection with a server, it's difficult to utilize sleep/low power modes since the device needs to listen (using its radio) for incoming data from alexa. You could look into using a lightweight protocol such as MQTT (https://learn.adafruit.com/mqtt-adafruit-io-and-you) instead of consistently polling the server.
You also may want to connect the ESP to its own battery source, such as a 2500mAh LiPo (https://www.adafruit.com/product/328). You may also be able to upgrade the blind's battery source to a 10,000mAh LiPo battery pack (such as this one: https://www.adafruit.com/product/1566).
brubell
by voodoo28 on Tue Sep 24, 2019 11:24 am
Thanks for the quick reply!
If I were to use MQTT, how would that affect the response time of the commands vs. polling the sever?
voodoo28
by brubell on Tue Sep 24, 2019 5:34 pm
MQTT is a protocol, as is "polling" (in this case, we're talking about sending HTTP commands like GET and POST directly to/from the server).
Check out more information about it here: https://learn.adafruit.com/alltheiot-protocols/mqtt
brubell
