how to call a function of disconnection
by omaromohsen on Sun Sep 29, 2019 9:34 am
I am a newbie user of adafruit.io server when Isaw the documentation the file publishing and subscribing
# Example of using the MQTT client class to subscribe to a feed and print out
# any changes made to the feed.  Edit the variables below to configure the key,
# username, and feed to subscribe to for changes.
# Import standard python modules.
import sys
# Import Adafruit IO MQTT client.
from Adafruit_IO import MQTTClient
# Set to your Adafruit IO key.
# Remember, your key is a secret,
# so make sure not to publish it when you publish this code!
ADAFRUIT_IO_KEY = 'YOUR_AIO_KEY'
# Set to your Adafruit IO username.
# (go to https://accounts.adafruit.com to find your username)
ADAFRUIT_IO_USERNAME = 'YOUR_AIO_USERNAME'
# Set to the ID of the feed to subscribe to for updates.
FEED_ID = 'DemoFeed'
# Define callback functions which will be called when certain events happen.
def connected(client):
    # Connected function will be called when the client is connected to Adafruit IO.
    # This is a good place to subscribe to feed changes.  The client parameter
    # passed to this function is the Adafruit IO MQTT client so you can make
    # calls against it easily.
    print('Connected to Adafruit IO!  Listening for {0} changes...'.format(FEED_ID))
    # Subscribe to changes on a feed named DemoFeed.
    client.subscribe(FEED_ID)
def disconnected(client):
    # Disconnected function will be called when the client disconnects.
    print('Disconnected from Adafruit IO!')
    sys.exit(1)
def message(client, feed_id, payload):
    # Message function will be called when a subscribed feed has a new value.
    # The feed_id parameter identifies the feed, and the payload parameter has
    # the new value.
    print('Feed {0} received new value: {1}'.format(feed_id, payload))
# Create an MQTT client instance.
client = MQTTClient(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
# Setup the callback functions defined above.
client.on_connect    = connected
client.on_disconnect = disconnected
client.on_message    = message
# Connect to the Adafruit IO server.
client.connect()
# Start a message loop that blocks forever waiting for MQTT messages to be
# received.  Note there are other options for running the event loop like doing
# so in a background thread--see the mqtt_client.py example to learn more.
client.loop_blocking()
Now I want when i disconnect the callback the function in the main program I tried using a flag with a value contradicting the value in connected function and counter
 global loop_flag
    loop_flag=0
    return(loop_flag)
but loop_flag is equal to 1 and there is a loop function
while loop_flag==1:
    print("Waiting for callback{}.format(counter))
    time.sleep(0.01)
    counter=counter+1
    if(counter==100):
     client.disconnect()
      break
any help will be appreciated
omaromohsen
Re: how to call a function of disconnection
by brubell on Mon Sep 30, 2019 9:29 am
Before we debug the code - are you trying to stop the loop in your main function after a disconnection event occurs?
brubell
