Adafruit FONA 800 Shield fails to connect to Adafruit IO
by jimk123 on Sun Sep 29, 2019 6:50 pm
Adafruit FONA 800 Shield - Voice/Data Cellular GSM for Arduino PRODUCT ID: 2468
Using a Arduino UNO board
I setup a Ting SIM card and ran the sample code Arduino\libraries\Adafruit_FONA\examples\FONAtest
and was able to send a SMS so the SIM card seems OK
Then I loaded the sample code for adafruit IO and set the config.h to
#define IO_USERNAME "myid from adafruit IO"
#define IO_KEY "key from adafruit IO"
and uncommented these lines:
#include "AdafruitIO_FONA.h"
AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
using Win10 IDE 1.8.5
when I compiled I got this warning but it uploaded
C:\Users\Jim\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/AdafruitIO_FONA.h:45:18: warning: extra qualification 'AdafruitIO_FONA::' on member 'networkStatus' [-fpermissive]
aio_status_t AdafruitIO_FONA::networkStatus()
and in the serial console I saw this:
connecting to Adafruit IOAttempting to open comm with ATs
---> AT
---> AT
this goes on for awhile...
---> AT
---> AT
Timeout: No response to AT... last ditch attempt.
---> AT
---> AT
---> AT
---> ATE0
---> ATE0
IO.STATUS=10 Network connection failed.
#include "config.h"
// set up the  feeds
  AdafruitIO_Feed *lightlevel = io.feed("lightlevel");
  int ctr =0;
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
   // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print("IO.STATUS=");Serial.print(io.status());Serial.print(" "); Serial.println(io.statusText());
    delay(500);
  // we are connected
  Serial.println();
  Serial.println("SETUP - CONNECTED");
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
  Serial.println("io.run");
  io.run();
  ctr++;
  Serial.print("CTR: ");Serial.println(ctr);
  lightlevel->save(ctr);
  delay(30000); // wait 30 seconds
Thoughts ?
jimk123
