MQTT ERROR rejected, only shared feeds may be published to
by jimk123 on Tue Oct 08, 2019 7:12 pm
try to follow the geofence guide here:
https://learn.adafruit.com/geofencing-w ... dafruit-io
in my code it defines the feed as:
const char LOCATION_FEED[] PROGMEM = AIO_USERNAME "/feeds/location/csv";
Adafruit_MQTT_Publish location_feed = Adafruit_MQTT_Publish(&mqtt, LOCATION_FEED)
it did not say anywhere in the guide to manually create the feed but I ended up creating one called 'location' after getting errors
in the serial window it says it successfully published the lat and lon values:
Publishing location: 0,41.898823,-72.676041,28.300001
Publish succeeded!
but when I look at https://io.adafruit.com under profile i see this error message pop up every 30 seconds ( I have a 30 second delay in the code):
MQTT ERROR: xxxxxxxxxxxxxxxxxx 172.58.238.198 PUBLISH ,,11,8,,,44,, OK -72.676067,29.200,0.17,269.1,1,,� rejected, only shared feeds may be published to
I have been using adafruit IO for a few weeks with some other boards publishing temp, humidity, etc but the feed name is always one value like 'temp' the one in the geofence code is called feeds/location/csv, not sure if I need to define something else in IO ?
jimk123
Re: MQTT ERROR rejected, only shared feeds may be published
by jefish on Fri Nov 15, 2019 4:05 am
I'm having the same problem when running Adafruit's Treat Tracker project, but the mqtt_fona example works fine. Haven't yet figured out how they publish differently, but some tips from Adafruit would be welcome.
jefish
by abachman on Mon Nov 18, 2019 11:46 am
The "only shared feeds may be published to" error message means IO didn't recognize the MQTT topic as being in the standard "{username}/{type}/{key}/{format}" pattern with "feeds" or "f" in the {type} slot and it didn't find the username you authenticated with in the {username} slot. For example, if I (abachman on IO) have a feed with the key "temperature", the topic I publish to would be "abachman/feeds/temperature/csv".
In the case of this example:
It may mean AIO_USERNAME is unset. It could also mean there's another publish event in the sketch that's using a different topic. Hard to tell without seeing source code.
Are you able to paste your sketch inside \[code\] tags with your IO key taken out?
- adam b.
abachman
by abachman on Mon Nov 18, 2019 11:51 am
Rereading the original error message, "PUBLISH ,,11,8,,,44,, OK -72.676067,29.200,0.17,269.1,1,,� rejected ..." means IO received ",,11,8,,,44,, OK -72.676067,29.200,0.17,269.1,1,,�" as the MQTT topic, which is not a valid MQTT topic.
- adam b
abachman
by jefish on Mon Nov 18, 2019 3:00 pm
For the treat tracker, I changed
const char PATH_FEED[] PROGMEM = AIO_USERNAME "/feeds/" PATH_FEED_NAME "/csv";
Adafruit_MQTT_Publish path = Adafruit_MQTT_Publish(&mqtt, PATH_FEED);
const char GOOD_CANDY_FEED[] PROGMEM = AIO_USERNAME "/feeds/" GOOD_CANDY_FEED_NAME "/csv";
Adafruit_MQTT_Publish goodCandy = Adafruit_MQTT_Publish(&mqtt, GOOD_CANDY_FEED);
to
Adafruit_MQTT_Publish path = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/treat-path/csv");
Adafruit_MQTT_Publish goodCandy = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/treat-good-candy/csv");
Essentially hardcoded the URL, which fixed my error.
Maybe you can adapt this to the geofence example.
jefish
by brubell on Wed Nov 20, 2019 10:27 am
jefish,
Thanks for the update. I've patched the treat-tracker code.
brubell
by jefish on Wed Nov 20, 2019 3:24 pm
Groovy.
Can you confirm that this change will also make the geofencing example work better for jimk123?
jefish
by brubell on Tue Nov 26, 2019 11:24 am
jefish wrote:Groovy.
It should - I don't currently have hardware to test it out.
brubell
