MQTT ERROR rejected, only shared feeds may be published to
Re: MQTT ERROR rejected, only shared feeds may be published
const char LOCATION_FEED[] PROGMEM = AIO_USERNAME "/feeds/location/csv";
const char PATH_FEED[] PROGMEM = AIO_USERNAME "/feeds/" PATH_FEED_NAME "/csv";
Adafruit_MQTT_Publish path = Adafruit_MQTT_Publish(&mqtt, PATH_FEED);
const char GOOD_CANDY_FEED[] PROGMEM = AIO_USERNAME "/feeds/" GOOD_CANDY_FEED_NAME "/csv";
Adafruit_MQTT_Publish goodCandy = Adafruit_MQTT_Publish(&mqtt, GOOD_CANDY_FEED);
Adafruit_MQTT_Publish path = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/treat-path/csv");
Adafruit_MQTT_Publish goodCandy = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/treat-good-candy/csv");
jefish wrote:Groovy.
Can you confirm that this change will also make the geofencing example work better for jimk123?
