Multiline Text Block
by JackTheSE on Mon Oct 21, 2019 5:41 pm
Is there any way to display a multi-line text message in a text block?
I've tried inserting \r\n in a text string sent to a text block, but it is ignored.
JackTheSE
Re: Multiline Text Block
by brubell on Tue Oct 22, 2019 10:11 am
Hi JackTheSE,
Text blocks do not have formatting options for multi-line messages. You would need to create two separate text blocks.
I think multi-line (and maybe additional formatting parameters) would be a welcome addition to the block. Could you add it to the block suggestion thread (viewtopic.php?f=56&t=130408)?
- brent r.
brubell
by JackTheSE on Fri Oct 25, 2019 6:42 am
Ultimately it would be fantastic to be able to design my own blocks somehow, and perhaps publish them open source for others to use. First thing I would do is design a much smaller toggle button with integrated text beside it. Second would be to design a text block that would display a table from a .csv file. Being able to develop my own blocks would convince me to go to a plus account.
Submitting my block ideas to a forum with the hope that something gets done by somebody, someday, maybe, is just not good enough for me. I'm trying to develop my own home automation system with Feather ESP32s and other products, but the current blocks are too limiting for a usable web interface.
JackTheSE
by brubell on Tue Oct 29, 2019 10:23 am
image (4).png (252.01 KiB) Viewed 272 times
Good news - we've added multiline text blocks to Adafruit IO and they're now live!
image (3).png (106.3 KiB) Viewed 272 times
brubell
by JackTheSE on Wed Oct 30, 2019 7:09 am
So this is fantastic news and very timely for me. I'm right in the middle of developing dashboards for a ESP32 HAZZAH project, and this is a game changer. Some questions...
(1) Is this available just for plus users? I'm not yet a plus user, and I just tried to enter a long line in the test block like you've shown above, and I didn't get a multiline preview.
(2) Will I be able to enter \r\n in a text string to get a new line, or does it just depend on how I sized my text block? The former would be the best implementation for me. I just ran a test with a string containing \r\n, and I didn't see a new line (and I also did not see those characters in the displayed string, so there were filtered out somehow, like they should be).
Edit: True to my word, I just upgraded to a Plus account, and it still doesn't work for me. I'll await your guidance on how to get this working.
JackTheSE
by brubell on Wed Oct 30, 2019 9:39 am
This isn't a plus-only feature, we'll place a "IO PLUS ONLY" designator when features are exclusive to IO+. Thank you for upgrading to Adafruit IO Plus, though! Checking with devs...
brubell
by brubell on Thu Oct 31, 2019 1:45 pm
The \n character is not escaped in HTML input fields, so in your examples, Adafruit IO sees it like two characters "backslash en", rather than the single "newline" character. You'll have to input multiline data from the API for now.
brubell
by JackTheSE on Thu Oct 31, 2019 2:19 pm
The \n character is not escaped in HTML input fields ... You'll have to input multiline data from the API for now
Does this mean that, starting with a String in Arduino/C++ (that I would otherwise send to a text block), I have to (1) convert it into HTML, (2) embed the carriage return where I want it, and then (3) send the HTML version to the block? Please note that I have near-perfect ignorance on how to do any of this this, as I'm a semi-newbie using IO. An example of doing these steps would go a long, long way to getting me started. I have looked through the API reference, but it's way, way above my head for the moment, at least.
And in your example screen above you show a feed creation screen that has a long test input, and then displays it as multiline text in the output box. When I try to replicate that, it doesn't work. Should it?
JackTheSE
by brubell on Thu Oct 31, 2019 3:23 pm
You'd be sending data (such as "multi\nline\nblock" ) as a string to Adafruit IO via Arduino.
The screenshot was taken during this block's development, it may have been removed/sanitized on the final version.
brubell
by JackTheSE on Fri Nov 29, 2019 6:30 pm
I finally got back to this, and yes, it works exactly like I wanted. Sending a String with \n embedded in it results in a new line, just as it would with a serial print of the same String. However, when I send something like
String Table = "This is Line 1\n   This is Line 2";
the leading blanks of Line 2 are stripped away. I would like to use spaces to indent lines if that's possible. Beyond just indenting, I would like to send a multi-row table with aligned columns if possible. Note that I didn't use any construct like your "multi\nline\nblock" suggestion above. Is that HTML code? I don't know how to directly send HTML code to a multiline text box, if that's what you suggested.
JackTheSE
by brubell on Mon Dec 02, 2019 11:00 am
This isn't supported in the current multi-line block, could you add a suggestion to the block suggestion thread and we'll take a look into implementing this? HTML code is not supported, though, we may be able to add Markdown syntax to the block.
brubell
by graeaquil on Tue Dec 17, 2019 2:13 am
JackTheSE wrote:Is there any way to display a multi-line text message in a text block?
I've tried inserting \r\n in a text string sent to Nox VLC a text block, but it is ignored.
graeaquil
by abachman on Tue Dec 17, 2019 10:58 am
Hi JackTheSE,
You can change the multiline block to "Preformatted" in the block settings and that will cause it to render in a monospace font with all spacing intact. It would work particularly well for columnar data.
- adam
abachman
