I am getting errors on my Pi Zero W
by kflmiami420 on Thu Oct 24, 2019 3:30 pm
This is just for a DHT22 that sends Temp and Humidity to the IO
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 160, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.5/socket.py", line 733, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 603, in urlopen
chunked=chunked)
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 344, in _make_request
self._validate_conn(conn)
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 843, in _validate_conn
conn.connect()
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 316, in connect
conn = self._new_conn()
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connection.py", line 169, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0xb5d59990>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File "/home/pi/.local/lib/python3.5/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/connectionpool.py", line 641, in urlopen
_stacktrace=sys.exc_info()[2])
File "/home/pi/.local/lib/python3.5/site-packages/urllib3/util/retry.py", line 399, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/temperature/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5d59990>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
File "1-dht22io.py", line 31, in <module>
aio.send(temperature_feed.key, '{0:.2f} F'.format(temperature))
File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 154, in send_data
return self.create_data(feed, payload)
File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 254, in create_data
return Data.from_dict(self._post(path, data._asdict()))
File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 126, in _post
data=json.dumps(data))
File "/home/pi/.local/lib/python3.5/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/home/pi/.local/lib/python3.5/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/home/pi/.local/lib/python3.5/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/.local/lib/python3.5/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/home/pi/.local/lib/python3.5/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/temperature/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5d59990>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
And this is for a bme280 sensor is also wired to the same Pi Zero W
Temperature: 89.6 F
Humidity: 37.0 %
Pressure: 1016.1 hPa
Altitude = 7.43 meters
Reading BME280 Sensor...
Sending BME280 data to adafruit io...
Temperature: 89.6 F
Humidity: 37.0 %
Altitude = 7.80 meters
Temperature: 89.6 F
Humidity: 37.0 %
Altitude = 7.49 meters
Temperature: 89.6 F
Humidity: 36.0 %
Altitude = 7.93 meters
Temperature: 89.6 F
chunked=chunked)
conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0xb5bf9590>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/temperature2/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5bf9590>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
File "3-bme280io.py", line 54, in <module>
aio.send(temperature_feed.key, '{0:.2f} F'.format(temperature_data))
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/kflmiami420/feeds/temperature2/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5bf9590>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
I clear the terminal
and re start the python3 script and come back later during the day and its has given me these errors.
kflmiami420
Re: I am getting errors on my Pi Zero W
by brubell on Tue Oct 29, 2019 10:50 am
Hi kflmiami420,
Sorry you're having issues with the IO Python library - I'm going to try to replicate this error from my end. Could you please post your entire code (with adafruit io credentials omitted)?
This error means that a DNS error occurred and the urllib/requests library was unable to resolve the IP address. Is your Raspberry Pi connected to a VPN? Do you have a firewall on your network?
brubell
by kflmiami420 on Tue Oct 29, 2019 4:17 pm
Sure ,
I have both sensors wired to the same Raspberry Pi Zero W
But they are running two different scripts one is for the DHT22 and the other is for the BME280
import time
import Adafruit_DHT
from Adafruit_IO import Client, Feed
DHT_DATA_PIN = 10
LOOP_Delay = 35
ADAFRUIT_IO_KEY = 'KEY Numbers go here '
ADAFRUIT_IO_USERNAME = 'USER name goes here'
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
try: # if we already have the feeds, assign them.
    temperature_feed = aio.feeds('temperature')
    humidity_feed = aio.feeds('humidity')
except RequestError: # if we don't, create and assign them.
    temperature_feed = aio.create_feed(Feed(name='temperature'))
    humidity_feed = aio.create_feed(Feed(name='humidity'))
dht22_sensor = Adafruit_DHT.DHT22
while True:
    humidity, temperature = Adafruit_DHT.read_retry(dht22_sensor, DHT_DATA_PIN)
    temperature = temperature * 9/5.0 + 32
    humidity = humidity + 7
#    print('Temp={0:0.1f}*F Humidity={1:0.1f}%'.format(temperature, humidity))
    print('sending DHT22 data to adafruit io...')
    print('Temperature: %0.1f F' % temperature)
    print("Humidity: %0.1f %%" % humidity)
    aio.send(humidity_feed.key, '{0:.2f} %   '.format(humidity))
    time.sleep(90)
This is for the DHT22 sensor . Do you think I need to combine the DHT22 and BME280 into one to eliminate the error ?
This is the BME280 to Adafruit IO code
#Author(s): Brent Rubell for Adafruit Industries
#Copyright (c) 2018 Adafruit Industries
#Licensed under the MIT license.
#All text above must be included in any redistribution.
#Re edited by KFLMIAMI420
# BME280 on rasperry pi zero w running debian buster October, 2019
# Take readings from a BME280 Sensor attached to a Raspberry Pi Zero W
# Print readings to Terminal Window
# Upload readings to Adafruit IO IOT Portal
# Convert Raw readings from C to F
# Add Decimal to Altitude upload to IO Portal
# Add Humidity correction for Sensor Error
import time
import board
import busio
import adafruit_bme280
from Adafruit_IO import Client, Feed, RequestError
LOOP_DELAY = 0
ADAFRUIT_IO_KEY = 'Key numbers go here '
ADAFRUIT_IO_USERNAME = 'User name goes here '
    temperature_feed = aio.feeds('temperature2')
    humidity_feed = aio.feeds('humidity2')
    pressure_feed = aio.feeds('pressure2')
    altitude_feed = aio.feeds('altitude2')
    temperature_feed = aio.create_feed(Feed(name='temperature2'))
    humidity_feed = aio.create_feed(Feed(name='humidity2'))
    pressure_feed = aio.create_feed(Feed(name='pressure2'))
    altitude_feed = aio.create_feed(Feed(name='altitude2'))
i2c = busio.I2C(board.SCL, board.SDA, frequency=100000)
bme280 = adafruit_bme280.Adafruit_BME280_I2C(i2c)
bme280.sea_level_pressure = 1017.02
while True:
    print('Reading BME280 Sensor...')
#    time.sleep (2)
    temperature_data = bme280.temperature
    # convert temperature (C->F)
    temperature_data = int(temperature_data) * 1.8 + 32
    humid_data = bme280.humidity
    # humidity correction for sensor error. for better  readings get readings from DHT22 humidity on this hat
    humid_data = int(humid_data) + 10
    pressure_data = bme280.pressure
    alt_data = bme280.altitude
    print('Sending BME280 data to adafruit io...')
#    time.sleep (2)
    print('Temperature: %0.1f F' % temperature_data)
    print("Humidity: %0.1f %%" % humid_data)
    aio.send(humidity_feed.key, '{0:.2f} % '.format(humid_data))
    print("Pressure: %0.1f hPa" % pressure_data)
    aio.send(pressure_feed.key, '{0:.2f} Mbar'.format(pressure_data))
    print("Altitude = %0.2f meters" % alt_data)
    aio.send(altitude_feed.key, '{0:.2f} meters'.format(alt_data))
    time.sleep(100)
To answer your questions
No VPN
Just a basic Xfinity modem to a Wifi Router
The Raspberry Pi Zero W does have a Static IP address
I do have separate Pi hole Raspberry Pi Zero W on a different static IP address > Should I white list io.adafruit.com ?
kflmiami420
by brubell on Tue Oct 29, 2019 4:40 pm
No, because the issue you're running into is with a library dependency and not something within the sensor code.
Could you temporarily disable the Pi-Hole to see if it's causing a network issue? You could try ping'ing io.adafruit.com from your Pi first, to see if it can resolve the IP address directly.
brubell
by kflmiami420 on Tue Oct 29, 2019 6:20 pm
Ok I have Disabled My Hole Device
kflmiami420
by brubell on Wed Oct 30, 2019 9:44 am
kflmiami420 wrote:Ok I have Disabled My Hole Device
Are you hitting the same error?
brubell
by kflmiami420 on Wed Oct 30, 2019 2:20 pm
Yes Same issue
kflmiami420
by kflmiami420 on Thu Oct 31, 2019 1:20 pm
I whitelisted IO.ADAFRUIT.COM It seems to help so far no errors in 4 hours of testing .
What data is io.adafruit.com collecting that a pihole Pi would interrupt the uploads ?
kflmiami420
by brubell on Thu Oct 31, 2019 1:52 pm
kflmiami420 wrote:I whitelisted IO.ADAFRUIT.COM It seems to help so far no errors in 4 hours of testing .
We've had success with a Raspberry Pi, Pi-Hole and Adafruit IO before.
However, I'm not sure what sites/DNS servers the PiHole was configured to block. This could be something particular about the Pi Hole setup, or about how your Raspberry Pi W was setup.
What filter list(s) did you select for your Pi-Hole? Possibly the list is blocking AWS hosts or Cloudflare.
Reason: edited to be more concise
brubell
by kflmiami420 on Wed Nov 06, 2019 7:57 pm
Still have the errors
kflmiami420
by brubell on Mon Nov 11, 2019 4:46 pm
kflmiami420 wrote:Still have the errors
Are you still using the Pi Hole, or are you trying a different network setup? Are the errors you're receiving still related to the DNS resolution for io.adafruit.com?
brubell
by kflmiami420 on Tue Nov 12, 2019 7:23 pm
I just set up the pi hole per your tutorial and chose one of them not the first one . i was getting all kinds of traffic from all the wifi automation switches and plugs , alexa so I started blacklisting all the traffic until things stopped working . Very few White listed domains added but in there are Adafruit , IOAdafruit , Discord, Github, Raspberrypi.org, Twitter, Ebay , Amazon.com .
You mentioned in a previous post that adafruit IO works with AWS ? Do you have those domains so I can look those up .
at this point Raspberry Pi weather Sensors with IOAdafruit is just works if I am sitting watching the terminal screen to look for the port 443 errors and restart the scripts
kflmiami420
by brubell on Wed Nov 13, 2019 11:22 am
Could you try resetting your Pi-Hole config to it's initial configuration?
brubell
by kflmiami420 on Fri Nov 22, 2019 2:58 pm
Thank you for all the help Brubell
I have given up on IO Adafruit . I decided to use another Pi Hole and the same occurs. I will just use a different platform
kflmiami420
