Feed Reading and Monitoring looping at every run
by JoseeMallah on Thu Oct 31, 2019 6:41 am
Hello everyone,
I have a problem using Adafruit IO with NodeMCU. I have a feed which value should be read and tested and an email/notification should be sent accordingly once per day. But it seems to me that it is called back at every call of io.run().
Can anyone help me solve this issue? I can post parts of the code if needed. I am using Arduino IDE.
Thank you
JoseeMallah
Re: Feed Reading and Monitoring looping at every run
by brubell on Thu Oct 31, 2019 11:24 am
I'm not sure what you mean by this. Could you elaborate, specifically - what should be happening and what's not happening?
io.run() only maintains an active connection with the Adafruit IO MQTT server.
brubell
by JoseeMallah on Thu Oct 31, 2019 1:10 pm
Here is my code. Please I have a project and I need your help everyone! :)
Is there a boolean method to check if there is new data on a feed?
int n = 0;
int i = 0;
String w = " ";
int lastn = 0;
/************************ Adafruit IO Configuration *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME    "JoseeMallah"
#define IO_KEY         "SNIP"
/******************************* WIFI Configuration **************************************/
#define WIFI_SSID       "Nada"
#define WIFI_PASS       "SNIP"
#include "AdafruitIO_WiFi.h"
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
/************************ Main Program Starts Here *******************************/
#include <ESP8266WiFi.h>
#include <AdafruitIO.h>
#include <Adafruit_MQTT.h>
#include <ArduinoHttpClient.h>
AdafruitIO_Feed *Door = io.feed("Door");
AdafruitIO_Feed *Temperature = io.feed("Temperature"); // set up the 'Temperature' feed
AdafruitIO_Feed *Weather = io.feed("Weather"); // set up the 'Weather' feed
AdafruitIO_Feed *ClothesTC = io.feed("ClothesTC"); // set up the 'ClothesTC' feed
AdafruitIO_Feed *ClothesC = io.feed("ClothesC"); // set up the 'ClothesC' feed
AdafruitIO_Feed *ClothesAC = io.feed("ClothesAC"); // set up the 'ClothesAC' feed
AdafruitIO_Feed *ClothesAH = io.feed("ClothesAH"); // set up the 'ClothesAH' feed
AdafruitIO_Feed *ClothesH = io.feed("ClothesH"); // set up the 'ClothesH' feed
AdafruitIO_Feed *ClothesTH = io.feed("ClothesTH"); // set up the 'ClothesAH' feed
AdafruitIO_Feed *WearToday = io.feed("WearToday"); // set up the 'WearToday' feed
void setup()
  // put your setup code here, to run once:
  Serial.begin(115200);
  // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  //pins
  pinMode (D0, INPUT);
  pinMode (D1, OUTPUT);
  pinMode (D2, OUTPUT);
  pinMode (D5, OUTPUT);
  pinMode (D6, OUTPUT);
  pinMode (D7, OUTPUT);
  pinMode (D8, OUTPUT);
  // set up a message handler for the feeds.
  // the handleMessage functions (defined below)
  // will be called whenever a message is
  // received from adafruit io.
  Door->onMessage(handleMessage1);
  Temperature->onMessage(handleMessage2);
  Weather->onMessage(handleMessage);
  ClothesTC->onMessage(handleMessageTC);
  ClothesC->onMessage(handleMessageC);
  ClothesAC->onMessage(handleMessageAC);
  ClothesAH->onMessage(handleMessageAH);
  ClothesH->onMessage(handleMessageH);
  ClothesTH->onMessage(handleMessageTH);
  WearToday->onMessage(handleMessageWT);
  // wait for a connection
  while (io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  Weather->get();
void loop()
  // put your main code here, to run repeatedly:
  //io.run();
  temperature(0, 0, 0, 0);
void temperature(int i, int j, int k, int t)
  io.run();
  digitalWrite(D6, LOW);
  digitalWrite(D7, LOW);
  digitalWrite(D8, LOW);
  int val = analogRead(A0);
  float mv = ( val / 1024.0) * 5000;
  float cel = mv / 10;
  minute[i] = cel;
  delay(1000);
............. etc.............
    if (t == 0)
      Serial.print("sending data -> ");
      Serial.println(w);
      WearToday->save(w);
      digitalWrite(D6, HIGH);
      digitalWrite(D7, HIGH);
      digitalWrite(D8, HIGH);
    if (t == 86399)
      t = 0;
    else
      t++;
    temperature(i, j, k, t);
..........etc............
void handleMessage(AdafruitIO_Data *data)
  String Weather = data->toString();
    Serial.print("received <- "); [b][u]// this part keeps looping every around 50 seconds and I do not know why[/u][/b]
    Serial.println("High/Low: ");
    Serial.println(Weather);
    delay(500);
    Serial.println("Done");
    int high = Weather.toInt();
    Serial.println(high);
And apparently this part is not saving value to arrays:
void handleMessageAC(AdafruitIO_Data *data)
  String ClothesAC = data->toString();
    Serial.println(ClothesAC);
    nbac++;
    AC[nbac] = ClothesAC;
JoseeMallah
by brubell on Thu Oct 31, 2019 3:16 pm
Yes, when you set up a message handler in your code (i.e: https://github.com/adafruit/Adafruit_IO ... ub.ino#L58), the handleMessage function (https://github.com/adafruit/Adafruit_IO ... ub.ino#L99) will be called whenever a message from the feed its linked to receives data.
In your handleMessage function, it's odd that it's getting called..
    delay(500);
Your Weather feed seems to be attached to this function(Weather->onMessage(handleMessage);). Is there anywhere in your code where the weather feed is written to? On the Adafruit IO Website, is the weather feed updated every ~50 seconds? What data is it getting? Is updating with data sent to the feed by the sketch, or garbage data?
brubell
by JoseeMallah on Thu Oct 31, 2019 3:30 pm
I get values once per day from ifttt where I made an applet which gets the daily high/low temperatures from Weather Underground at 7:00 am so values are added once daily mainly. And values seem to be right. So the handleMessage should be run once daily so at reset first. I was thinking of something that tests if there are new values to run the method. I was trying to use global variables but I still couldn't get it working. Any idea?
JoseeMallah
by JoseeMallah on Thu Oct 31, 2019 4:46 pm
If you @brubell say that the code is right, I notice that the NodeMCU is restarting for a reason which I do not know. The code is working good but due to the reset data from the feed is loaded again. Using the serial monitor, every 1 minute now more than 50s maybe, I see something not very understandable saying boot and reset maybe and shpwing Connecting to Adarfruit IO again. So I mainly need help please to know/fix what is/may be causing this. I am using the A0 pin to read temperature, D0 to digitalRead pin 2 on Arduino UNO and D6, D7 and D8 to control a 4 pin RGB LED (other pins are available in pinMode but not really used now) and I established a common ground for the 2 boards.
JoseeMallah
by JoseeMallah on Sun Nov 03, 2019 12:48 pm
This topic is now closed.
JoseeMallah
