ESP8266 Disconeected from Adafruit IO
by bharwood on Mon Nov 04, 2019 1:36 am
Hello, I'm working on the Cloud Connected Power Meter guide found here: https://learn.adafruit.com/build-a-clou ... he-project
My circuit is the same and I'm using the code from the github. I was having this error originally when running the Github code. I did change 4 lines of code. I changed ssid to the SSID of my network and the password to the password for my network. I also added my AIO USERNAME and AIO_KEY from adafruit.io clicking on AIO KEY.
Connecting to MYSSID
WiFi connected
IP address:
10.0.0.91
Connecting to Adafruit IO...
Exception (3):
epc1=0x4020a940 epc2=0x00000000 epc3=0x00000000 excvaddr=0x4023dae1 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd60 end: 3fffffc0 offset: 01a0
3fffff00: 4023dae1 d47c0734 402085f0 d47c0734
3fffff10: 3ffee3ba 3ffee398 3ffee3fb 4020297a
3fffff20: 3ffe85f2 3ffee3ba 3ffee398 3ffee66c
3fffff30: 3ffe85f2 3ffee3ba 3ffee398 40202bca
3fffff40: 40105848 3ffee604 0000001c 40204953
3fffff50: 3ffedd40 3ffee740 3ffe8528 3ffee66c
3fffff60: 3ffe85f2 3ffee398 3ffee604 402013d8
3fffff70: 4020622a 000003e8 000003e8 3ffee66c
3fffff80: 3ffe85f2 3ffee4ac 3ffee330 40201512
3fffff90: 402085f0 5b00000a feefeffe feefeffe
3fffffa0: 3fffdad0 00000000 3ffee63c 402054bc
3fffffb0: feefeffe feefeffe 3ffe8528 40101099
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
Results from Exception Decoder:
Exception 3: LoadStoreError: Processor internal physical address or data error during load or store
PC: 0x4020a940
EXCVADDR: 0x4023dae1
Decoding stack results
0x4020297a: Adafruit_MQTT::connectPacket(unsigned char*) at D:\Users\Braden\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp line 626
0x40202bca: Adafruit_MQTT::connect() at D:\Users\Braden\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp line 155
0x40204953: HardwareSerial::write(unsigned char) at C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266/HardwareSerial.h line 154
0x402013d8: connect() at D:\Users\Braden\Documents\Arduino\adafruitio_00_publish\sketch_nov03a/sketch_nov03a.ino line 229
0x4020622a: delay(unsigned long) at C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266\core_esp8266_wiring.cpp line 57
0x40201512: setup() at D:\Users\Braden\Documents\Arduino\adafruitio_00_publish\sketch_nov03a/sketch_nov03a.ino line 105
0x402054bc: loop_wrapper() at C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\cores\esp8266\core_esp8266_main.cpp line 122
It repeated loops this with the LED in the circuit flashing and then the OLED flashing Ready! back and forth. I found a temporary solution online which suggested removing PROGMEM from any line that it was in, in the code itself. This seemed to fix the above error. Now the error message I get is:
WiFi connected
IP address:
10.0.0.91
Connecting to Adafruit IO... Connection failed
Retrying connection...
Connection failed
Connection failed
I'm not sure what is causing the issue. I've also run the following sketch found here https://learn.adafruit.com/adafruit-io- ... e-sketches. The adafruit IO library example sketch adafruitio_00_publish and changed while loop to print out io.statusText instead of .'s. I also setup the config.h file with my SSID, password, AIO username, and AIO key.
The change:
while(io.status() < AIO_CONNECTED) {
//Serial.print(".");
Serial.println(io.statusText());
delay(500);
When I run this to see if I can even connect to Adafruit IO, I get these messages
Network disconnected.
Disconnected from Adafruit IO.
It appears that it takes a little bit and then connects to my network and then doesn't connect to Adafruit IO.
At this point, I'm not sure why I can't even get the example sketches to connect to Adafruit IO. Any ideas?
bharwood
Re: ESP8266 Disconeected from Adafruit IO
by brubell on Fri Nov 08, 2019 5:39 pm
Hi bharwood,
Could you try running this sketch to see if you can connect to Adafruit IO?
https://github.com/adafruit/Adafruit_MQ ... sp8266.ino
It might be your WiFi Network, can you run this sketch below to test your network connectivity?
https://learn.adafruit.com/adafruit-fea ... -wifi-6-33
brubell
