ADAFRUIT_MQTT_Client Login and Pwd in loop()
by jmontgomry on Thu Nov 07, 2019 8:07 am
I know that ADAFRUIT_MQTT_Client must be istantiated before setup()
but my MQTT_login and MQTT_password are stored in EEPROM and as
you know I can read from there only in setup() or loop().
How resolve this ?
This was asked before and there was no answer. Anyone?
jmontgomry
Re: ADAFRUIT_MQTT_Client Login and Pwd in loop()
by brubell on Mon Nov 11, 2019 4:58 pm
You may want to switch to the Adafruit MQTT Library.
Could you try storing your Adafruit IO Username and Active Key in EEPROM, and then instantiating the MQTT client here:
https://github.com/adafruit/Adafruit_MQ ... 66.ino#L44
The MQTT client doesn't connect to Adafruit IO's MQTT server until the MQTT_connect function is called.
https://github.com/adafruit/Adafruit_MQ ... 6.ino#L111
What you might want to try is reading your credentials within the MQTT_connect function and create a new Adafruit_MQTT_Client in that function with the credentials read from EEPROM.
brubell
by borghuisb on Mon Feb 22, 2021 11:04 am
jmontgomry wrote:I know that ADAFRUIT_MQTT_Client must be istantiated before setup()
How resolve this ?
I am trying to do the same thing - have you been able to get this to work? Thanks!
borghuisb
