Get All Feed Data
Get All Feed Data
by JoseeMallah on Mon Nov 11, 2019 1:27 pm
Hello everyone,
I need to get all feed data in Arduino code (I am using NodeMCU with Arduino IDE). I found this for Python:
# Import library and create instance of REST client.
from Adafruit_IO import Client
aio = Client('YOUR ADAFRUIT IO USERNAME', 'YOUR ADAFRUIT IO KEY')
# Get an array of all data from feed 'Test'
data = aio.data('Test')
# Print out all the results.
for d in data:
    print('Data value: {0}'.format(d.value))
How to do the same in Arduino IDE? I want to save each string/data value in array of strings if there is a needed type conversion.
Thank you
JoseeMallah
Re: Get All Feed Data
by brubell on Mon Nov 11, 2019 1:54 pm
Check out the examples bundled with the Adafruit IO Arduino Library
https://github.com/adafruit/Adafruit_IO_Arduino
brubell
by JoseeMallah on Mon Nov 11, 2019 2:31 pm
Can you please precise which one although I may be insisting?
JoseeMallah
by brubell on Mon Nov 11, 2019 4:52 pm
JoseeMallah wrote:Can you please precise which one although I may be insisting?
I don't think you'll be able to get all the feed data from Adafruit IO Arduino. as it allows you to either get the current state of a feed, or subscribe to updates from the feed via the Adafruit IO MQTT Server.
If you can perform HTTP GET requests from your NodeMCU, take a look at the Get Feed Data endpoint for the Adafruit IO API:
https://io.adafruit.com/api/docs/?shell#get-feed-data
This is what Adafruit IO Python uses. You may want to use the ESP8266's WiFiSSLClient example and modify it for that API endpoint.
If you hit any issues or roadblocks, feel free to post up below.
brubell
