wifi post data to IO Feed encounter runtime error
by davidluca123 on Tue Nov 12, 2019 1:54 am
Hi, I am currently trying to post data collected by my adafruit to my account feed. However, I am encountering a runtime error when I try to post my data. I am currently trying to run the code following the "Internet Connect!" tutorial here https://learn.adafruit.com/adafruit-air ... et-connect
My code currently looks like this.
import time
import board
import busio
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
from adafruit_io.adafruit_io import IO_HTTP
import adafruit_requests as requests
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
print("ESP32 SPI webclient test")
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.D13)
esp32_ready = DigitalInOut(board.D11)
esp32_reset = DigitalInOut(board.D12)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
"""Use below for Most Boards"""
status_light = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.2) # Uncomment for Most Boards
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
counter = 0
while True:
    try:
        print("Posting data...", end='')
        data = counter
        feed = 'welcome-feed'
        payload = {'value':data}
        response = wifi.post(
            "https://io.adafruit.com/api/v2/"+secrets['aio_username']+"/feeds/"+feed+"/data",
            json=payload,
            headers={"X-AIO-KEY":secrets['aio_key']})
        print(response.json())
        response.close()
        counter = counter + 1
        print("OK")
    except (ValueError) as e:
        print("Failed to get data, retrying\n")
        print(e)
        wifi.reset()
        continue
    response = None
    time.sleep(15)
However, I am getting this error message:
  File "main.py", line 55, in <module>
  File "main.py", line 46, in <module>
  File "/lib/adafruit_esp32spi/adafruit_esp32spi_wifimanager.py", line 221, in post
  File "adafruit_requests.py", line 275, in post
  File "adafruit_requests.py", line 236, in request
  File "adafruit_requests.py", line 190, in request
  File "/lib/adafruit_esp32spi/adafruit_esp32spi_socket.py", line 83, in connect
  File "/lib/adafruit_esp32spi/adafruit_esp32spi.py", line 696, in socket_connect
  File "/lib/adafruit_esp32spi/adafruit_esp32spi.py", line 624, in socket_open
  File "/lib/adafruit_esp32spi/adafruit_esp32spi.py", line 319, in _send_command_get_response
  File "/lib/adafruit_esp32spi/adafruit_esp32spi.py", line 308, in _wait_response_cmd
  File "/lib/adafruit_esp32spi/adafruit_esp32spi.py", line 295, in _wait_response_cmd
  File "/lib/adafruit_esp32spi/adafruit_esp32spi.py", line 277, in _check_data
RuntimeError: Expected 01 but got 00
where line 46 in "main.py" is "headers={"X-AIO-KEY":secrets['aio_key']}" in the wifi.post call.
I have tried running
curl -F 'value=42' -H "X-AIO-Key: {io_key}" https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data
in my terminal and was able to successfully post my data onto my feed through that. However, I cannot successfully get my main.py code to run on my Adafruit.
I am currently using a Feather M04 and an AirLift FeatherWing - ESP32 WiFi Co-Processor.
I will greatly appreciate it if you can help me understand why this error is happening or direct me on how to fix this issue.
davidluca123
Re: wifi post data to IO Feed encounter runtime error
by brubell on Wed Nov 13, 2019 11:36 am
Are you able to run the ESP32SPI simpletest code on your Feather+AirLift: https://github.com/adafruit/Adafruit_Ci ... pletest.py
Do you receive the same error?
brubell
by davidluca123 on Wed Nov 13, 2019 12:15 pm
Hi brubell, I think I am able to get data from the JSON_URL correctly. I get a syntax error when trying to print out my JSON file.
Here is my output:
code.py output:
ESP32 found and in idle mode
Firmware vers. bytearray(b'1.2.2\x00')
MAC addr: ['0x88', '0x7b', '0x11', '0x12', '0xcf', '0xa4']
   Brown-Guest      RSSI: -73
   eduroam      RSSI: -73
   Brown      RSSI: -74
   Brown-Guest      RSSI: -83
   eduroam      RSSI: -83
   eduroam      RSSI: -83
   Brown      RSSI: -83
   Brown-Guest      RSSI: -84
   eduroam      RSSI: -85
Connecting to AP...
Connected to Brown-Guest    RSSI: -70
My IP address is ***.**.***.***
IP lookup adafruit.com: ***.**.**.***
Ping google.com: 65535 ms
Fetching text from http://wifitest.adafruit.com/testwifi/index.html
<html>
<head>
<meta http-equiv='refresh' content='1; url=http://wifitest.adafruit.com/testwifi/index.html?cmd=redirect&arubalp=12345'>
</head>
</html>
Fetching json from http://api.coindesk.com/v1/bpi/currentprice/USD.json
  File "code.py", line 57, in <module>
  File "adafruit_requests.py", line 132, in json
ValueError: syntax error in JSON
davidluca123
by brubell on Thu Nov 14, 2019 10:38 am
Could you update the adafruit_requests module to the latest version in the Adafruit CircuitPython Bundle?
https://github.com/adafruit/Adafruit_Ci ... hon_Bundle
Also please try updating ESP32SPI to the latest version as well.
- brent r.
brubell
by davidluca123 on Thu Nov 14, 2019 5:53 pm
Thanks for the reply. I have updated to the most recent version of adafruit_requests.py and adafruit_esp32spi from the Github. Unfortunately, I am still getting the error.
davidluca123
by davidluca123 on Fri Nov 15, 2019 2:42 am
Sorry, after digging more into the code, I think the requests.get() call actually might not be returning the correct value in the ESP32SPI simpletest code. From the output of the ESP32SPI simpletest code, it seems like the r = requests.get(TEXT_URL) did not get the the text content from the url but instead the just the buffer. When I printed out the content for the r = requests.get(JSON_URL) call, I also only get the buffer which is b"<html>\n<head>\n<meta http-equiv='refresh' content='1; url=http://api.coindesk.com/v1/bpi/currentprice/USD.json?cmd=redirect&arubalp=12345'>\n</head>\n</html>\n".
It seems like the correct output of the simplist code should be:
davidluca123
by davidluca123 on Fri Nov 15, 2019 3:32 am
I am also trying to connect with MQTT to see if that will work, however, I seem to be getting an error as well.
Here is my MQTT code:
import time
import board
import busio
import neopixel
from adafruit_minimqtt import MQTT
try:
except ImportError:
    raise
print(status_light)
temperature_feed = secrets['aio_username'] + 'feeds/temperature'
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connected(client, userdata, flags, rc):
    # This function will be called when the client is connected
    # successfully to the broker.
    print('Connected to Adafruit IO! Listening for topic changes on %s' % onoff_feed)
    # Subscribe to all changes on the onoff_feed.
    client.subscribe(onoff_feed)
def disconnected(client, userdata, rc):
    # This method is called when the client is disconnected
    print('Disconnected from Adafruit IO!')
def message(client, topic, message):
    # This method is called when a topic the client is subscribed to
    # has a new message.
    print('New message on topic {0}: {1}'.format(topic, message))
wifi.connect()
mqtt_client = MQTT(socket,
                   broker='io.adafruit.com',
                   username=secrets['aio_username'],
                   password=secrets['aio_key'],
                   network_manager=wifi)
# Setup the callback methods above
mqtt_client.on_connect = connected
mqtt_client.on_disconnect = disconnected
mqtt_client.on_message = message#requests.set_socket(socket, esp)
#test_feed = io.send_data('welcome-feed', 42)
print('Connecting to Adafruit IO...')
mqtt_client.connect()
counter = 0
while True:
    # Poll the message queue
    mqtt_client.loop()
    # Send a new message
    print('Sending photocell value: %d...' % counter)
    mqtt_client.publish(temperature_feed, counter)
    print('Sent!')
    counter += 1
    time.sleep(1)
The error I am getting is :
  File "main.py", line 74, in <module>
  File "adafruit_minimqtt.py", line 202, in connect
MMQTTException: Invalid broker address defined.
Sorry if I am bombarding you with many updates, I want to give you as much info as I can to help you in solving the problem.
davidluca123
by davidluca123 on Sun Nov 17, 2019 12:47 am
Solved the problem :) It had to do with my wifi configuration
davidluca123
by brubell on Mon Nov 18, 2019 11:26 am
davidluca123 wrote:Solved the problem :) It had to do with my wifi configuration
Excellent - do you know what the exact issue was, so I can help people solve this in the future?
brubell
by graeaquil on Thu Dec 19, 2019 2:03 am
davidluca123 wrote:Hi, I am currently trying to post data collected by my adafruit to my account feed. However, I am encountering a runtime error when I try to post my data. I am currently trying to run the code following the "Internet Connect!" tutorial here https://learn.adafruit.com/adafruit-air ... et-connect
Speed Test Scrabble Word Finder
import time
import board
import busio
import neopixel
try:
except ImportError:
    raise
counter = 0
while True:
    try:
        data = counter
            json=payload,
        response.close()
        print("OK")
        print(e)
        wifi.reset()
        continue
    response = None
    time.sleep(15)
graeaquil
