Attached is the error message which occurs during to upload the sketch.
- Code: Select all | TOGGLE FULL SIZE
Arduino: 1.8.9 (Windows 8.1), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Disabled (new can abort), All SSL ciphers (most compatible), 4MB (FS:none OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Build options changed, rebuilding all
fatal: not a git repository (or any of the parent directories): .git
Executable segment sizes:
IROM : 362560 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27140 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 2732 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25368 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 393684 bytes (37%) of program storage space. Maximum is 1044464 bytes.
Global variables use 29352 bytes (35%) of dynamic memory, leaving 52568 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.7
Serial port COM20
File "C:\Users\john_000\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0/tools/upload.py", line 25, in <module>
esptool.main(fakeargs)
File "C:/Users/john_000/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 2840, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "C:/Users/john_000/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
File "C:/Users/john_000/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/pyserial\serial\__init__.py", line 88, in serial_for_url
instance.open()
File "C:/Users/john_000/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/pyserial\serial\serialwin32.py", line 62, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port 'COM20': FileNotFoundError(2, 'The system cannot find the file specified.', None, 2)
Please let me know what needs to be done to allow this sketch to compile correctly.
Thank you for your help!
John Chintall
