Connection works, but ESP does nothing
by nilsfast on Wed Nov 13, 2019 4:34 pm
Hello, I have the follwing code aswell as an io-feed. In the serial monitor it says "Got ON" and "Got OFF", but the ESP doesn't set the pin to high.
//Viral Science
// www.youtube.com/c/viralscience
//Google Assistant Home Automation
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#define Relay1            D1
#define Relay2            D2
#define Relay3            D3
#define Relay4            D4
#define WLAN_SSID       "*****"             // Your SSID
#define WLAN_PASS       "2***********9"        // Your password
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com" //Adafruit Server
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "nilsfast"            // Username
#define AIO_KEY         "d***************************7"   // Auth Key
//WIFI CLIENT
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Subscribe Light1 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/LED"); // Feeds name should be same everywhere
Adafruit_MQTT_Subscribe Light2 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/Schalter 2");
Adafruit_MQTT_Subscribe Light3 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/Schalter 3");
Adafruit_MQTT_Subscribe Light4 = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/Schalter 4");
void MQTT_connect();
  Serial.begin(115200);
  pinMode(Relay1, OUTPUT);
  pinMode(Relay2, OUTPUT);
  pinMode(Relay3, OUTPUT);
  pinMode(Relay4, OUTPUT);
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
  mqtt.subscribe(&Light1);
  mqtt.subscribe(&Light3);
  mqtt.subscribe(&Light2);
  mqtt.subscribe(&Light4);
  MQTT_connect();
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(20000))) {
    if (subscription == &Light1) {
      Serial.print(F("Got: "));
      Serial.println((char *)Light1.lastread);
      int Light1_State = atoi((char *)Light1.lastread);
      digitalWrite(Relay1, Light1_State);
    if (subscription == &Light2) {
      Serial.println((char *)Light2.lastread);
      int Light2_State = atoi((char *)Light2.lastread);
      digitalWrite(Relay2, Light2_State);
    if (subscription == &Light3) {
      Serial.println((char *)Light3.lastread);
      int Light3_State = atoi((char *)Light3.lastread);
      digitalWrite(Relay3, Light3_State);
    if (subscription == &Light4) {
      Serial.println((char *)Light4.lastread);
      int Light4_State = atoi((char *)Light4.lastread);
      digitalWrite(Relay4, Light4_State);
void MQTT_connect() {
  int8_t ret;
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) {
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);
    retries--;
    if (retries == 0) {
      while (1);
  Serial.println("MQTT Connected!");
nilsfast
Re: Connection works, but ESP does nothing
by franklin97355 on Wed Nov 13, 2019 5:54 pm
What do you get if you try to print the value of Light4_State?
franklin97355
by nilsfast on Thu Nov 14, 2019 12:13 pm
I get "0" back.
nilsfast
by franklin97355 on Thu Nov 14, 2019 1:22 pm
In both the on and off states?
franklin97355
by nilsfast on Tue Nov 26, 2019 1:24 pm
Yes.
nilsfast
by brubell on Mon Dec 02, 2019 11:33 am
What about
Light1_State
brubell
