Data Sharing
Data Sharing
by rajendran78 on Thu Nov 21, 2019 3:08 am
Can I send data that is from a particular feed to a database like firebase? or Adafruit has any database that I can use?
rajendran78
Re: Data Sharing
by brubell on Mon Nov 25, 2019 11:28 am
Hi rajendran78,
We don't have anything publicly exposed on the Adafruit IO Website. However, you could forward data as it is received by feeds using a MQTT client running on a local server like a Raspberry Pi (you may be able to code one up using Adafruit IO Python, or another client library).
brubell
Re: Data Sharing
by rajendran78 on Tue Mar 10, 2020 4:45 am
Can i check if data posted by MQTT can be accessed by other backend applications like mobile apps (e.g. to track location)
rajendran78
Re: Data Sharing
by brubell on Tue Mar 10, 2020 11:31 am
rajendran78 wrote:Can i check if data posted by MQTT can be accessed by other backend applications like mobile apps (e.g. to track location)
You'd need a way of accessing the Adafruit IO API (https://io.adafruit.com/api/docs/#adafruit-io-http-api) from these apps.
brubell
cron
